P1000 fox shocks is it worth the money
1BadDart
1BadDart
1,455
13,495
W. KY
Thats where the Elka Stage 5 are different you can adjust both high and low speed shaft travel, vie of two different compression knobs and have a third adjustment for rebound.
If I do shocks these are the ones I'll save my nickles and dimes for.
208,731
Like Smitty said, two knobs are better then one :)
I haven't install my rear shocks yet :( but I am happy with my fronts I do not know if they are worth the money but I shore do like the way the front ones perform, I know this is wrong but I adjusted my high and low speed as soft as I could and cranked up the high speed nob to control the bottoming out resistance.
My butt meter is telling me there is a difference, I think they suck up more bumps with out bottoming out as much as the Fox's, who knows maybe my views is jaded because I drank the cool-aide.
What kind of trails you ride/terrain you ride in? I you ride in the rock/logs and you have your high speed shaft travel set soft, you might try setting your rebound faster, to get shock extended back out for the next impact?????
Reactions: GPR1500SC
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
Corn stubble, chiseled field, and such like I really have not took the time to tune on this thing we just use it enjoy it and abuse it that why I own a Honda
Reactions: JTW
208,731
Heres rule of thumb for rebound setting, if you ride sand whoops you will want a slower rebound setting, to keep the bucking sensation down,if you ride rocks, need to speed it up.
GPR1500SC
GPR1500SC
861
2,426
North East MO
  2. Talon X LV
Thanks for the help I will play with the rebound when I find the time.
markc
58
69
eastern kentucky
finally got time to play with my rear shocks. Put 5 turns on the preload and I'm very happy with it.
ToddACimer
ToddACimer
Pioneer 1005-2
3,746
15,866
Oshkosh, Wi
Which compression setting are you running and do you have any trouble with rear tire chatter in soft soil? I found with more preload I couldn't eliminate wheel hop. I also have only 250 miles of trail riding with no cargo and no passenger but that's my normal payload.
markc
58
69
eastern kentucky
middle setting have not experience any wheel hop.no extra weight just two people most the time
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
So you fellas with fox or Elka shocks. Can you put 500 lbs of crap in the back and be able to adjust it to ride level?
I've been sitting on a bucket pondering an air bag system for when I haul something heavy. Just like my truck has..... @JTW @moparornocar
Reactions: JTW
Bking
Bking
9
Tn
thanking about upgrading my deluxe p1000 5. to the fox shocks that comes on the le model. Question is it worth the extra money
Its worth every penny they cost ...
Unless you have le model ... totally different ride .. i put fronts on and in middle of the first ride with them the first time i had service i ordered rears, but i ordered walker evans for rear. Best investment by far ....
P
Ptafoya
7
Arizona
I will sell you my set of Foxy's for a $1000.00 plus shipping they have about 250 miles on them plus or minus some I put them on for my Colorado trip.
I will be up grading to Elka 5 if these sell, if not I will keep them.
Have you sold these yet?
