It does take a little getting used to. The best way I've found is to make sure your (or her) heel is resting firmly on the floor and pivot your ankle for throttle input. Heel up doesn't work because of the feedback loop that's created. Press the gas...machine accelerates, pulling your foot away from the pedal, so the machine slows.... jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows.... jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows....jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows.... jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows....jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows.... jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows....jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows.... jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows....jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows.... jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows....jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows.... jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows....jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows.... jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows....jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows.... jamming your foot into the pedal so the machine accelerates, pulling your foot away from the pedal so the machine slows....if you're still reading this...you have waaaay too much time on your hands.[/QUOT
You need A doctor and A job
