P500 Getting new wire into existing battery box.
States
Spirit lake idaho
Installing auxiliary battery but can’t figure out how to get new battery cable in to existing battery box for routing to isolator. Any help would be appreciated and pictures would be awesome,
Reactions: TxDoc
P
pappyo
593
2,377
Positive cable : Enter & Follow the same path as OEM run up & over top of battery.
Not fun : Tight fit can be done.
Ground cable : pick-up outside of battery box.
Sorry no Pictures:
States
Spirit lake idaho
Finally got it done! Battery fits like a glove in under hood tray. Negative buss bar, fuse box, Isolator all mounted on under hood cross member. Auxiliary battery ground disconnect switch located under dash on passenger side. Main battery positive routed up in chassis.
While thinking about the routing of the main battery positive cable I installed installed a 30” light bar on roof, 2- 4” cubes on back glove box with rockers for lights and USB ports and a AMP METER that gives readings for both batteries. A Equipment Defender locking 2-1/2 gallon gas can rack and new uhm skid plates with aluminum stick stoppers.
Now it’s time to do first service since I only have 80 miles on it.
Thanks for everybody’s input.
156,429
No pics?
Reactions: Mudder
The Green Goat
The Green Goat
1,747
12,371
Gonna need pics.
Reactions: Mudder
Any pics of the aux battery install?
Here’s one….
97A24E18 5893 43D3 8481 B9CB2C05ED0C
Montecresto that's clean! Very nice. Any details on wires coming from original stock battery, maybe a diagram?
Thanks. Sorry I do not have a diagram. I ran #4 welding wire along the frame rail in split loam above my full skid plate to the front.
CSP500
9
Kentucky
The Green Goat, that's nice! Did you run the factory wire that was connected to the original battery + up to the switch like below? So with this set up I would need to bring two positive wire and one negative from existing battery box.
1625752804854
The Green Goat
The Green Goat
1,747
12,371
Yup.
20210507 161305
CSP500
9
Kentucky
The Green Goat, thanks for that pic. How tough was it to get the original positive wire that was on the battery up to the switch? I guess I need to get back down at the battery but what is the other red wire attached to? Thank you for your time.
Reactions: Mudder
