P500 Good spot for a fire extinguisher.
Glazer
Glazer
24
78
I always have a fire extinguisher on board on whatever I am driving because I have had to use them several times. after doing some looking, I found the style I liked but didn't want to spent $65.00 to $70.00.
So I made one myself, I bought a piece of 1" x 1/8" - 4" mild steel, 1- stainless steel 1/4" bolt and nut,
1- 1/4" x 1" pull pin and 4 - hose clamps. cut and welded it up. to remove the extinguisher, just pull the orange key tag that attached to the pull pin and lift the extinguisher off. I wanted it mounted to the P5 so it will always be with the machine.
This is what I copied. https://www.amazon.com/Micephon-Adj...gler-Unlimited/dp/B07HMKPZDX/?tag=sxsweb24-20
FE pic
Mudder
Mudder
NTC Ambassador of Walls
11,602
87,332
Nice, wish I had one. Any extras lying around? LOL. Any close up pics would be appreciated, to copy fab.
Glazer
Glazer
24
78
Sorry, but I didn't take any pics of the finish product, but in my original post, I added a link to where I copied the ideal, it has pictures and measurements on how to fab it.
Gunslingertom
Gunslingertom
104
171
SW Missouri Ozarks
You inspired me to build one on this colder than the north pole day. So since it's too cold to make concrete today, I whipped one out for myself. Please don't pay attention to the welds. the battery went dead on my auto darkening helmet and all I had was a scratched up half lens piece of crap, that I can't see through to save my own life. Anyway, they stuck, that's the main thing.Fire extinguisher mount 1 Fire extinguisher mount 2 Fire extinguisher mount 3 Fire extinguisher mount 4 Fire extinguisher mount 5 Fire extinguisher mount 6
JCart
JCart
895
2,020
Kamloops, BC Canada.
Looks great easy to access, nice work.
I mounted mine on the floor hump, with a standard mounting bracket right against vertical seat wall,below the park brake. Its out of the way, quick access, easily seen. Only caution might be if you have someone sitting in the middle, not really a problem for me as my “kids” are adults now and don’t fit well there hahaha.
j
JCart
JCart
895
2,020
I haven't ridden with any rzr's, but if I start then I will have to invest in this. :D
Kinda surprised that’s not come up already I typically ride alone for work. The last couple years it’s been really dry with lots of fine fuels like dry grass and needles and in my jurisdiction I carry hand fire fighting tools. So in my rear tub I’ve got one of those plastic piss pump fire fighting cans, (fill of water), Pulaski and typically a shovel and chainsaw. Usually water hose dry leaves and debris off matchine after work everyday to flush out keerap. Not interested in being the cause of a wildfire on crown (Govt) forest lands.
Cheers,
j
104,776
Mine is above and behind passenger seat
Reactions: NTCPrezJB
Bruce4795
112
248
Arizona
This is what I copied. https://www.amazon.com/Micephon-Adjustable-Extinguisher-Wrangler-Unlimited/dp/B07HMKPZDX/ref=sr_1_57_sspa?crid=3SZYB2QV5WHOZ&keywords=utv+fire+extinguisher+mount&qid=1551491408&s=gateway&sprefix=utv+fire,aps,175&sr=8-57-spons&psc=1
