educ8tedguess
Good morning all,
After every lengthy ride, I typically do a machine check on my ATV's and UTV's. I just go through and inspect bolts, and all that fun stuff. When checking this time, I came across something that didn't look quite right. I will put a couple of pictures below. What you will be looking at is where the front drive shaft goes into the motor. There is a rubber "o" ring that split and there appears to be a little oil strewn about. Any ideas of what this may be? (Besides a good indication that I should buy a shop manual)
Thanks in advance.
Thanks in advance.
