P500 Help please - installing switches
L
lakelander
21
24
Vancouver, BC Canada
I am installing 2 mictuning switches. One for the winch and the other for the lights. Where on the dash is the best place and how did you cut out. I don't want to mess it up and end up with a hole in the dash :). Thx
JollyJoker
JollyJoker
92
192
Minnesota
If you take off the front hood and look at the backside of the dash, you will see imprints for cutout areas for rocker switches.
68,140
Cutting them is not hard. Getting them straight is a PITA.
You can find a templet in some of the honda accessory instructions. Print and use that.
Or. Order a switch panel if you your future holds more switches.
Reactions: lakelander
Eltobgi
Eltobgi
4,599
15,187
North Dakota
8856FEB9 0B22 4B42 AAE5 B45C4F5FF9C2 C2C0CC27 7BFD 456C 93E2 A3ABFBF6D615 3BCF0542 D86E 4D05 A623 65ADC6C970D1 849D0EB9 3B82 4BC1 9F9D FEBFD01E5F9C
Mudder
Mudder
NTC/TAP Transition Member
11,834
90,079
Used the OEM cutout lines for horn and rear light, plus a voltmeter/usb and battery charger socket. Wiggling a box cutter gave cleaner cutouts than an oscillating tool. I could see the lines from the front in the glare of a light.
76BF6D3B 26D7 4A36 81E3 9EE79406CFE6
Eltobgi
Eltobgi
4,599
15,187
North Dakota
Looks like you used black silicone on themo_O
Mudder
Mudder
11,834
90,079
Nope, photo misleading. Those are sloppy rough cuts from first trying an oscillating blade, switched to utility knife thereafter. You have a good eye. LOL
C6F5F6A4 085D 4BBA 933C 34C8A1BEF382
Reactions: monaco and Eltobgi
P
PFflyers
5
6
Texas
Is there any advantage/disadvantage in what wire you install your switch for accessory lights?
Reactions: Hondasxs
68,140
On my 700. I did tap one of the headlight wires. This allowed the switch backlights to come on only when headlights were on. I liked it and it worked as designed.
But for the 1000. I just wired to key-on acc wire.
And my second 1000. I just wired to the AUX on switch.
Really just dont tap a wire that is of importance. Let's say if something happened to that connection and you shorted it out. Could you do without that circut for a while.
Headlights, maybe. Ignition, No.
Mudder
Mudder
11,834
90,079
Just found out the brake pedal interlock switch is on the headlight fuse, if blown, no starter engagement. Thought I had a bad interlock switch, learned out the hard way on other ride.
Reactions: Zaleski
Zaleski
Zaleski
67
176
Ohio
Even if the unit is in neutral?
Mudder
Mudder
11,834
90,079
It was on another machine that required the brake pedal depressed in any gear, but for the P500 it is also on the headlight fuse. Good to know in advance.
Reactions: Zaleski
P
PFflyers
5
6
Texas
Ok, I understand about taking care to tap a non essential system. I was wondering if there was any advantages or disadvantages as to what side of the accessory to install the switch, in the hot side or ground side.
