The other day My wiper stopped working, so today I thought I would tidy things up under the hood and figure out why the wiper doesn't work. I checked the fuses to see if they are good. Fuses where good but looked oxidized. The fuse bay was full of water?? so I blew it out, sprayed it with contact cleaner, cleaned the fuses and put them back in. Checked for key on power, that was good but the connector was full of water?? A bit more checking and I found my under seat fan doesn't work, The voltmeter in the dash shows 6 volts and goes out when I turn on the light bar. When I pulled out the connector for the fan and the light they are wet and corroded Pulled out all the connectors and they are all the same
I blew everything out with compressed air, cleaned things up with scotch brite and a welding tip cleaner, sprayed contact cleaner on everything blew it off again applied dielectric grease and put it back together. still the same problem, I have 12v going to the fuse block 12v key on power, good ground, but the output of every connector is 6v
Where would you look next?
