Honda Pioneer 500 on tracks?
I
iam_canadian22
20
23
Finally got out today, still barely any snow, very odd for up here in northern ontario, usually a good couple feet by now and still at just a couple inches, anyways for the tracks the loss in speed is noticeable, it sure doesnt lack power though, everywhere we brought it it didnt hesitate, i still need to do a bit of modification to the front antirotation brackets to be able to adjust them properly since if you recall i modified an existing kit i had, all in all very pleased and cant wait for more snow
Reactions: Dp5hunter
IdahoPioneer
IdahoPioneer
244
600
Emmett, Idaho
Holy crap that's a ton of surface area! I bet that would get you through more powder than any other track kit on the market. Very impressive.
NPN
NPN
96
192
Manitoba
For my situation I could never use skis in the front (if I could I would be using snowmobiles). The non plowed road to my cabin gains almost 2000 ft elevation. Often times it is muddy/rocky at the bottom and I'm into 2 ft of snow before reaching the cabin. This requires a fully tracked vehicle.
That said, even without diff lock 4 tracks will far outperform 2 based on what I've seen.
It’s that time of year to think about tracks again...can you tell me more about your experience? Noise level? Excessive snow spray into the cab? Practical useable speed expectations? Is p/s essential? And, is there noticeable wear on the P500 as a result? Thanks...much appreciated!
rocmar
rocmar
4,741
5,773
4 CORNERS
He used the word 'actually' 12 times in 3 minutes. I 'actually' went back and counted. Sorry I notice stupid sh** like that.
Nice machine though.
HaHa.....
yes he did...
the cost of tracks.....
....way to spendy for me
E
easyrider158
fairbanks Alaska
Re: Tracks
Here you go... The First P5 on tracks!
Don't have any info on it.. Yet...
All I know is I would love to take it for a spin.
View attachment 2350 View attachment 2351
I am also thinking about getting Tracks on my 500 . they want me to upgrade to a 700 or 1000 to drive them . I really don’t need to go faster than 25 mile an hour in the snow I just want to be able to climb a hill, ill be following this blog , thanks tom
Toddmcleish
Capreol
Winter atv tracks on my pioneer 500. Had to be modified to fit.
20180121 164556
Reactions: solrus and Mudwing
How do these tracks work if the trail intermittently turns to mud and dirt/rock here and there? Is continuous snow an absolute requirement or will there be damage to the tracks??
Reactions: Russ989
Russ989
Russ989
22,597
146,810
Tracks will typically handle anything but the wear life depends on the surface they are in contact with. I wouldn’t want to run tracks full time, instead of one bearing assembly you would have 5 to 8 to worry about.
NPN
NPN
96
192
Manitoba
Looks good. I like the ground clearance. How is it handling in the snow? Pros/Cons?
Its excellent in the snow, great floatation. Just don’t compare it to a snowmobile for speed and agility. Steering is pretty hard, a very harsh ride on anything hard packed. It pulls like a mule! I will likely order the soft doors cuz you get buried inside the cab with snow that is flung up from the tracks. The motor area, entire front end etc gets blasted with snow. Some of it melts and forms ice blocks. So, its very capable at slower speeds but you have to put up with some inconveniences and take 20 minutes after riding in anything more than 4 inches of snow to do a lot of cleaning before parking it. Unless you always keep it in a warm place. (I brought it into the shop to melt and dry out...ended up with a frozen gas line as a result. Keep gas line antifreeze withyou!)
NPN
NPN
96
192
Manitoba
The Kimpex Tracks that I use are very tough and made for all year conditions like mud, rocks, bush trails and sand etc. They don’t need lubrication like snowmobile sliders. I bought the Kimpex because you can replace individual bearings if needed.
Reactions: Montecresto
NPN
NPN
96
192
Manitoba
The Kimpex WSS4 Tracks that I use are very tough and made for all year conditions like mud, rocks, bush trails and sand etc. They don’t need lubrication like snowmobile sliders. I bought the Kimpex because you can replace individual bearings if needed and with proper adjustment, they dont rub on the frame in the front thus allowing full range of steering. Most other brands come with a steering limiter kit, not needed. I also bought a cheap tractor type steering knob...definitely helps the steering. [ /QUOTE]
NPN
NPN
96
192
Manitoba
I’m going to attempt making some sort of fender flares that come out as far as the tracks...this would direct most of the snow spray down from the cab. Looking for ideas as to some sort of flexible but ridged plastic rated for cold Canadian winters!
Upload 2019 2 26 19 5 47
