• Welcome to HONDASXS.com
    If you are a guest please take time to REGISTER with us. Stay up to date on the Honda Side by Side line and take part in our online forum. Check out the FAQ. Once you register you can start to make post. Users will respond to your question or statement. To start viewing messages, select the forum that you want to visit below or click the board index to see a list of all forums. Thanks and have fun.
Honda Talon 1000 Accessory Installtion Instructions
Discussion in 'Talon 1000 Accessories and Modifications' started by HondaTech, Mar 17, 2019.
  1. Talonpalooza
    Talonpalooza Active Member
    Feb 25, 2019
    116
    230
    Ownership:
    Talon X
    Again, I/we all appreciate your input on this forum and thank you for posting installation instructions as I used most of them. If I come across as frustrated, I am. But certainly not at you or anyone on this forum.
    #21 Talonpalooza, Apr 9, 2019
  2. HondaTech
    HondaTech Working For Mother Honda!!
    Lifetime Member Club Contributor
    Dec 30, 2015
    1,265
    2,746
    Sent you a PM.
    I understand your frustration, I've never
    once been offended by anything you've said. Trust me we've been just as frustrated about some of this stuff as well.
    #22 HondaTech, Apr 9, 2019
  3. WhiteLightning
    WhiteLightning Well-Known Member
    Feb 19, 2017
    1,290
    4,248
    Magnolia Arkansas
    Ownership:
    1000-3
    I set in one last week. Not nearly enough leg room for my 6'5"
    Sent from my SM-G965U using Tapatalk
  4. Reneb3
    Reneb3 Member
    Oct 14, 2017
    42
    19
    Cross sc
    Ownership:
    1000-3
    Revised the mechanical winch mount after looking at the accessory bumper instructions. Moved the small curved pieces to the top hole. Also changed the fairlead hardware. The winch plate is now bolted in two positions. Makes more sense.
    10DCC799-7D2E-4BC4-B794-436463F774A5.jpeg 520ACB06-C432-407A-93FE-28AE4F9D6DC5.jpeg
  5. Reneb3
    Reneb3 Member
    Oct 14, 2017
    42
    19
    Cross sc
    Ownership:
    1000-3
    I also completed the electrical hookup. Used the pioneer instructions as a guide. The contractor sits under the cowl. I had to remove the roof and windshield. Easy actually. Then remove to cowl and you have access to the mounting location and the winch power wires taped w blue tape. The contractor is color coded. Next install the sub harness. ThE black plug plugs into the back of the accessory socket and the wire you remove plugs back into the sub harness. This powers the contractor. Next cut a hole in the glove box for the controller. I mounted it outside the glove box so I can close it. The controller plug also plugs into the sub harness. The sub harness then routs to the contractor with three wires. Color coded, can’t screw it up. The last plug is used for the optional switch plate. It is capped. The only thing left to do is connect the hot lead in the battery box. It’s in blue tape. I connected it to the starting solenoid. That’s how it is on the pioneer and the lug looks the right size. Last is to run the wires to the winch. I put the blue one on top. It should now work with the key on. Cable tie everything up and your done.
    3E7E42D0-2365-4EB7-A74C-34852D4370C7.jpeg BABE5704-6B0C-47F4-B346-932C62F1A8F5.jpeg 76A53A77-20E0-44C4-8271-F39137E55A9A.jpeg
  6. Reneb3
    Reneb3 Member
    Oct 14, 2017
    42
    19
    Cross sc
    Ownership:
    1000-3
    The wiper looks harder. I can’t find any pictures showing it installed! I guess I’ll have to wait for instructions.
  7. HondaTech
    Dec 30, 2015
    1,265
    2,746
    Bulletin says Winch instructions will be here the 15th and Wiper will show up around 11th.
  8. Reneb3
    Reneb3 Member
    Oct 14, 2017
    42
    19
    Cross sc
    Ownership:
    1000-3
    The 11th as in tomorrow? That would be nice.
  9. Reneb3
    Reneb3 Member
    Oct 14, 2017
    42
    19
    Cross sc
    Ownership:
    1000-3
    Honda tech, do you know the part number for the connectors that plug into the white connectors on the switch plate harness? I’m assuming you’re supposed to either cut and lug them or buy the connector to create pigtails to hook up to switches and loads.
  10. Neohio
    Neohio Beast of the East
    Lifetime Member Supporting Member Club Contributor
    Dec 22, 2016
    8,341
    27,609
    Painesville Ohio
    Ownership:
    1000-5
  11. HondaTech
    Dec 30, 2015
    1,265
    2,746
    I haven't actually seen 1 of then yet, so I'm not sure which plugs your referring to. I'd assume it's the plugs like on the P1K that's made to plug into the switches included with the other accessories.
    #31 HondaTech, Apr 11, 2019
    Neohio likes this.
  12. Reneb3
    Reneb3 Member
    Oct 14, 2017
    42
    19
    Cross sc
    Ownership:
    1000-3
    This is the actual connector I need. It comes on the wiper harness. This plugs into one of the 5 mating connectors for power and a separate connector attaches to the switch.
    5F1AAEA1-0D8C-4A74-AC25-E4DE83CFB49D.jpeg 30E9A1BC-7846-4135-A252-6BFCFA112745.jpeg C9794E8E-B436-4B78-AD87-CAE2C4446EE5.jpeg
  13. Hondasxs
    Hondasxs Club Founder
    Staff Member Vendor Lifetime Member Club Contributor
    11,600
    23,948
    Ownership:
    1000-5
  14. Neohio
    Dec 22, 2016
    8,341
    27,609
    Painesville Ohio
    Ownership:
    1000-5
  15. Neohio
    Dec 22, 2016
    8,341
    27,609
    Painesville Ohio
    Ownership:
    1000-5
  16. Hondasxs
    11,600
    23,948
    Ownership:
    1000-5
    I already have a handful ordered and expected to arrive Saturday.
    @Reneb3,
    I'll contact you and send you 1 or 2 to test.
    Neohio likes this.
  17. Talonpalooza
    Feb 25, 2019
    116
    230
    Ownership:
    Talon X
    Looks like Honda posted instruction on accessory website. There is a another plug in front of steering wheel that is plugged into a dummy plug. I guess you are to use that adapter. Also shows carving out a space to left of steering column for rocker switch. Not going to do that as long as I have some space on my accessory switchplate. But if I need room I know where it can go. Thanks for your
    HondaTech, if you get a part number please let me know... I will order some as well...
  18. Reneb3
    Reneb3 Member
    Oct 14, 2017
    42
    19
    Cross sc
    Ownership:
    1000-3
    The wiper instructions are there. Now I have to take all the stuff I just put back together apart. Should be easy the second time! Thanks for your help.
  19. Talonpalooza
    Feb 25, 2019
    116
    230
    Ownership:
    Talon X
    I am looking to order some as well.... so let me know...Thanks
    Hondasxs likes this.
  20. Talonpalooza
    Feb 25, 2019
    116
    230
    Ownership:
    Talon X
    W
    Where is there? Don't see them... Thanks
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
    Dismiss Notice
Loading...
