Talon Honda Talon Winch Mount Instructions
Bigblue1
77
92
NC
The instructions says not to install on the factory bull bar.
  • winch install.pdf
Reactions: nm6r
Bigblue1
77
92
NC
I installed it with the factory bull bar, I don't see any problem with it and it works fine. The only problem is that I have to take it of and reinstall if my bumpers ever come. Kinda hoping that Super ATV will get their bumpers out first.
Jamie-in-WV
Jamie-in-WV
35
81
West Virginia
IMG 0142
Bull bumper stays with no issues with Warn Axon 5500s
Reactions: Mikehallad
HondaTech
We've installed a 5500 Warn Axion on the stock bumper using the Honda mount.
I think its just normal Honda over engineering and cautiousness, and possibly greed to get you to buy their bumpers, lol.
Jamie-in-WV
Jamie-in-WV
35
81
West Virginia
It's a shame to have such a good looking piece of equipment hid so far back to where no one will ever notice it.
Reneb3
46
24
Cross sc
I like where it is mounted, don’t like the upside down to much, bit the clutch was easy to reach. Just on the wrong side. I used it twice this weekend, once to pull up a steep muddy hill and once a real deep muddy hole. Bumper was fine. I used the stock one as well. Waiting for the aluminum one to come in.
Jamie-in-WV
Jamie-in-WV
35
81
West Virginia
IMG 0145
IMG 0146
IMG 0146
After having everything bolted in yesterday evening I was looking at the setup this evening and removed the winch and noticed the spool on the axon was way wider than the opening for the Honda plate, so off it came and I cut 1" from both sides and the top of the plate to allow the winch to use the entire spool width. I feared it would only allow it to spool the rope center spool, if that makes sense I'll insert pics of what I did. Also had to open up the space for the fair lead.
wrighteous
wrighteous
108
501
next week I think L and W fab will have theirs out.
They will be at Windrock this weekend with their green R with high arch front a arms and trailing arms with badazz custom cage
Reactions: Sawpilot
Sawpilot
Sawpilot
57
151
West Virginia
barnwoodbuilds.com
Thank you very much I just called them you are absolutely correct She’s got my name to order one Next week.. she wasn’t sure of price when I find out I’ll let people know
motorman18
439
277
Laurel, MS
What tire are you running in the mud
Reneb3
46
24
Cross sc
The factory tires. Only was stuck in a hole once, I don't think it would have mattered what tire you had, they toss the mud up at least 8 feet. I hate mud. Thing was covered in it by the end of the weekend. The roof had at least 30 pounds on it.
rbtnt
rbtnt
76
61
Where did you mount the Axon switch? Can it be mounted in the Honda switch panel or next to the light switch?
HondaTech
Our customer wanted it on the left side of the steering wheel. Did not have the Honda switch panel or any plans on installing it.
rbtnt
rbtnt
76
61
Thanks. I found a photo in another thread.
Cat963
Bunker Hill WV
I can not find the “accessory” place to plug in the factory Honda winch controls the picture in the pdf directions is very vague and didn’t see any connections that would match up. Any help would be appreciated.
67,170
I think this is what you are looking for.
This view is from the front of the machine behind the plastic cover.
It's the cigarette plug you are looking for. 625461b697db5e25ffdf95a592c2af0d
