So I replaced my ITP steel wheels and Bighorn 2.0s with some ITP SD bead locks (5+2) with Sedona Mud Rebel RTs (26x9-12 front 26x11-12 rear) and the RB3 wide track kit. The P5 is about 57'' wide in the rear and about 55.5'' wide in the front now. I'm looking to make it as wide as possible for stability without putting too much stress on the machine or pushing it wider than I should for steering or other reasons I may not be aware of. It drives fine as is but I have only been putting around on my property so far.
Is anyone else running a setup that is this wide? If so, have you run into any issues with steering or stressing components too much?
Thanks,
Wis
Thanks,
Wis
