P500 "I have questions" thread
156,656
Any old jack should work as long as you can get under it then raise it high enough. Never used sway control on any of my open trailers, just don't put too much weight behind the axle and it'll pull straight.
The Green Goat
The Green Goat
1,749
12,380
Does the P5/2 have a tilt switch, where is it, and how can I disable it?
Bomersteve35
98
307
Portland or
  2. Other Brand
2 Questions for trailering peoples:
1> Any recommended jacks for 5x10 utility trailer? Scissor VS bottle? or is a $20 harbor freight scissor jack good enuf?
Have a good one in the truck I can drag over and use if I need to, just looking for one to keep on the trailer toolbox.
2> Anybody put on trailer sway control for these little things? Trailer is max rated at 3000lbs, I might get over 2000 once in a while, but not very often. Was a trucker for like 7 years, so used to hauling bigger stuff, this is the smallest trailer I've ever hauled, lol.
I saw a video a while ago of a guy that had his front tinge jack mounted in a receiver. He would take it off and go back to the axles where he had a receiver sticking out just between both tires. Plugged it in and cranked and lifted both tires off the ground. Simple setup and worked well and you would always have a trailer jack with you. Myself I have a gmc 2500 with camper and trailer behind. My truck rear axle is about 6000 on its own. So ya I have a nice 20ton bottle jack
Reactions: hallic
The Green Goat
The Green Goat
1,749
12,380
Are the Honda nerf bars compatible with the SSS skid plates? How about with the optional rock sliders on the skid plates?
156,656
If by compatible you mean just bolt on? No, the instructions call out cutting a notch even into the factory skid. I had to take an angle grinder to my aluminum rock sliders. Still worth it. 😏
208,013
I usually just take my shop floor jack, a lot more stable than a small jack.
Reactions: Mudder
lee
lee
Village Idiot
2,332
13,088
Springfield Ohio
I quit worrying about jacking the trailer when I got one of these (sorry, internet image).
1618274515466
I still have a screw jack for the truck if I need more lift.
Bigtee
Bigtee
556
1,213
Grayson, KY
I have an electrical question. I will be running all my accessories (except winch) through the Nilight relays with a positive trigger.
Can I just loop the the power source to all my switches from one power wire and then run individual power wires out to the relays? (#86 below)
This will prevent me from having so many single wires to just trigger the relay. I will be running single power wires to the relays (#30 below). I’m just trying to cut down on the wires coming from the positive bus bar.
0B948787 55E7 4477 8283 0C1EAF4605F4
The Green Goat
The Green Goat
1,749
12,380
I would think you would be perfectly fine to daisy chain all the switch wires together. They won't be high current since they are only used to trigger the relay, which will handle the higher current loads. That is essentially what I plan on doing for my other bank of auxiliary switches. For simplicity sake, I will be purchasing, probably 12-16 conductor, tray cable for this purpose. It'll be 12-16 (depends on what I can find) small gauge (probably 22-26awg) wires packed into one cable that will only be used for the switch loads. I think it'll drastically cut down on the wire clutter.
Something like this:
Tray cable
Bigtee
Bigtee
556
1,213
Grayson, KY
That's a good idea, I'll look for one with 8 to 12 wires.
Reactions: J80 and Mudder
11,317
84,090
You should be fine as you are not exceeding the total amps of the one wire rating. I just finished two switched relay circuits on my motorcycle, and had one bad relay that drove me crazy rechecking my wiring.
Reactions: Bigtee and J80
The Green Goat
The Green Goat
1,749
12,380
What turn signal/hazard/horn kit are you guys using? Was looking at XTC products, but they're real proud of their product.
Alternatives?
The Green Goat
The Green Goat
1,749
12,380
Is the factory 1-1/4" hitch strong enough for Tiger Tail duties without bending something? I have a 2" MFG Supply receiver as well, but I'd like to utilize that for a Hornet tire carrier with the TT underneath.
Reactions: Bigtee
