P1000 Injection issues
F
Flemz84
12
Australia
Good day all I have an injection issue as when I turn my machine on the injection on one cylinder runs flat out for awhile anyone had this issue before? I had the same issue as previous people have had like running rough and very fueley on one cylinder and if swap cylinders it follows. Have tried all the suggestions in previous posts and have found nothing but the injection issue
regards Ryan
Ps thanks for all the help
NTCPrezJB
NTCPrezJB
President of #NTC
101,756
908,837
Canton, OH
Also has engine light flashing 9x
Should be a combo of long and short flashes. Count them and post it or record it, upload to YouTube and post the link to it here.
have you replaced the injector wires? Site store sells a pigtail. But usually that solution is for a lack of fuel I think.
F
Flemz84
12
Australia
Ok as I’m Aussie I will do that tomorrow and post it. I did make my own pig tail and try them and it was still the same I’m beat the only thing I can think of is the ecu not responding
Reactions: Lady01
NTCPrezJB
NTCPrezJB
President of #NTC
101,756
908,837
Canton, OH
Any wire damage near the ecu?
Reactions: Lady01 and Mudwing
E
Ericthered
Eric The Red
271
522
Sparks, NV
Can you wash it? Dirty connectors will make this old girl a real b****.
Reactions: Lady01
P1K5Dave
P1K5Dave
2,181
8,165
Petoskey, MI
Not sure if the injector plug/wires are your problem either, just wanted to add that when mine went bad you couldn't really tell by inspection. Wires were still intact and seemed OK (where other guys have had wires pulling out and such.)
Replacing them fixed it.
Regarding your blinks, as mentioned before parse out long vs. short blinks. An injector circuit code would be two long and either 1 or 3 short blinks (21 or 23)
Reactions: Lady01
