P1000 Is this right?
Highcountry356
21
30
Colorado
OK, I am guilty of trying to find stuff to worry about. With that in mind, I installed a set of four 28x10-14 Roctane X2's mounted on ITP Hurricanes last week. I also put 1" RB3 spacers on the rear. When I look at the rear tires they have a noticeable bow in at the top. I don't remember seeing that with the stock set up. I'm assuming this is the way it should be but figured I'd ask the stupid question anyway. Thanks for your tolerance.
IMG 5330
Reactions: toddvdh and Isaiah
TripleB
TripleB
11,706
99,400
Caryville, Tennessee
When i noticed mine was like that, the rear wheel bearings were shot. When I put new bearings in, it straightened the tires up. If that's not it, u will have to get superatv rear arms, so u can adjust the camber.
Highcountry356
21
30
Colorado
The machine has 200 miles on it so wheel bearings are fine. I had no idea I'd need new rear arms just by changing out wheels/tires.
Reactions: Isaiah
TripleB
TripleB
11,706
99,400
If I take the spacers off the rear will that help reduce the camber issue?
I would think it would have to help but I'm not an expert. I have 2 inch spacers on the rear and 28 inch tires and don't have as much lean in as u do. Did you ride it around the driveway to let the suspension settle before u took this picture?
Reactions: Isaiah
DDDonkey
What model do you have, deluxe or base, and is there anything in the bed (weight wise). With the Deluxe you get load leveling rear shocks that should fix that after hitting a few bumps, I don't know what the base comes with. You don't need to change your a-arms because you changed your wheels, to me it looks like you squatting the rear end, but it is hard to tell from that one picture, does the other side look like that?
Reactions: Isaiah and TripleB
TripleB
TripleB
11,706
99,400
The base has load leveling also.
Reactions: Isaiah and DDDonkey
Highcountry356
21
30
Colorado
1000-5 Deluxe. There is a spare tire and a box with straps, tools, etc in bed. I did not take it for a ride just pulled it in and out of the garage. I sure hope I don't need A-Arms cuz this thing is turning into a money trap to get it where I need it to be before hunting season.
Reactions: Isaiah
MuskyHunter
MuskyHunter
94
216
Indiana
Following along since I’m about to do the same wheel spacer setup. I just went and looked at mine and stock it doesn’t have that much camber.
Reactions: Isaiah
Papaandhistoys
Papaandhistoys
134
227
Backwoods of northern Michigan
So, I’m following also! As I did the satv a-arms with 15” wheels and 30” tires on my LE model and I have what I would consider to much camber, especially in front.
Reactions: Isaiah
Ohio4x4
Ohio4x4
I brought the dishwasher
1,494
15,019
I'm still running stock arms in the rear. I had this same issue when preparing for May's overland trip. With all of my gear it looked like hell in the rear. To run loaded I had to put 2 5/8" preload in my fox shocks to get the squat out and straighten up. If you weren't wanting to spend the money for the aftermarket shocks there are some post about making spacers for the factory set up with black iron pipe. I opted to upgrade shocks for some adjustments because I always have something in the bed. It's nice to be able to tune the suspension to the use of the machine. I hope to go the next step soon and change spring rate on the foxes.
Highcountry356
21
30
Colorado
OK, so I emptied the bed and took it for a short ride and then measured how much the tires slant inward at the top (negative camber). I placed a level up against the tire and then tilted it out at the top until level and then measured it. The front is 3/8" and the rear 3/4". If a few of you guys could do that same measurement and let me know what your machines measure I would greatly appreciate it. Thanks!
MuDSlinger
MuDSlinger
204
1,108
Richland, WA
28 x 11 x 15 .... 2020
20191101 153610
I will take a pick from back tomorow however, have not saw this issue
Reactions: Isaiah
Highcountry356
21
30
Colorado
When I measured I went from the smooth part of the sidewall top and bottom and not the very ends of the tires.
Reactions: Isaiah
MuskyHunter
MuskyHunter
94
216
Indiana
I’m getting about 5/8th at the top drivers side. 3/8 on the passenger side. My tires sidewall bulges on the bottom so that causes a little bit. Mine is a 2021 with 75 miles on it.
Reactions: Isaiah
Highcountry356
21
30
Colorado
Are you talking the rear tires? If so, did you emaure the front? I could always jack mine up and put the OEM's back on to measure but blue locktited the spacers and really don't want to take them off.
Reactions: Isaiah
MuskyHunter
MuskyHunter
94
216
Indiana
I went out and drove around a few minutes empty. I now read about 3/8th on both rear tires and 1/8th if that on the front's. I'd say it has something to do with ride height and the load leveling shocks.
Mopower58
Mopower58
CST is the Best!
70,141
644,388
Crystal Springs,Ms.
I have 28's with 5+2 wheels and a 1 inch spacer and mine are straight up and down. I have standard rear shocks.
Reactions: Isaiah
Russ989
Russ989
22,569
146,535
It’s normal to have them lean in at the top a little, sometimes it will change with the terrain.
Reactions: Isaiah
