Jackal's 2024 Talon 1000X-4 Bolt on Bonanza! 😎
280,769
Rain dripping on your knee from the half assed OEM roof rain drip rail?
Madder than a wet hen and want to do something about it for $8?
Why not use the RV J-Channel rain gutter? 16 Ft for $24 enough for 3 machines.
Mount right onto windshield frame, fits the SuperATV glass windshield for Talons perfectly.
Note: Tested this after install by running garden hose full stream on roof, everything ran right down the J-channel as I expected it to. Definitely a win win on this little mod.
20241117 172858
20241117 172815
Notched out at drip rail and goes up underneath the roof line approx. 1" so roof drip rail overhangs into the J channel to funnel rain down the A pillar and not on your leg! VERY pliable rubber brush should not affect it, if so, replace the strip for $4.
20241117 172748
280,769
Took the Talon out for the first trail ride. Covered about 50 miles and it was a good ride. I really like the trail manners of the suspension and how the chassis handles overall. Got to train myself for low speed riding, the throttle response is really impressive, I have since added the AJK footrest as suggested by others. It likes cruising closer to 20 mph instead of 10. 😁
20241118 143947
20241118 143931
20241118 135140
20241118 134948
20241118 134922
GovtMule
GovtMule
21,440
183,856
Tennessee
I'm going to give this a go, it works exactly opposite of the Throttle Maxx where instead of planting your heel back you plant it forward against the AJK rest. May be the magic bullet I'm looking for.
You’ll like it. For reference this is the “setting” where I mounted mine. It has various bends but I think we are close to the same height. It works perfect for me.
IMG 8744
Vondy
Vondy
1,586
10,521
Houston,OH
Yeah, For how simple it is, it makes a huge difference.
280,769
95% there, got to adjust the fixed panels to align with moving doors and trim roof, but she's on there. Pretty detailed instructions, definitely a lot of thought went into design of this upper doors kit.
20241121 120002
20241121 120018
Coeus
Coeus
Major General
75,071
685,934
Signal Mountain, TN
  2. Talon R4 LV
As far as just the door panels, yes. 3 bolts each front door and 2 bolts each back door, and they just lift off. The 4 fixed panels would just stay put, taking them on / off would be a major PITA.
Are you planning to leave the fixed panels in for the in-season and remove them for the off-season?
280,769
I misread your post initially, yes I will leave the 4 fixed panel in place full time, maybe (but probably not) the rear upper doors with the dogs inside. So I will likely just remove the two front upper doors May through October
280,769
So been an interesting 36 hours. There is always perils in being an early adopter of new products.
Despite my best efforts the two fixed panels behind the front doors just didn't quite line up like I thought they should and the front doors closed harder than necessary rubbing the bottom of the aforementioned panels. Also the rear doors didn't quite follow the ROPS contour quite right.
Now all eight panels came pre-assembled with the bulb seals fully attached around the perimeter and rigid door frames. As seen here right out of the boxes:
20241120 185816
It then dawned on me the subtle bends in the poly panels rear doors and the fixed panels between the front and rear doors were exactly opposite to what they should be. Surely they weren't assembled backwards, lo and behold they were. So I spent 4 hours disassembling what seemed like 80 4mm bolts, pulling off all the bulb seals and swapping the seals to the opposing panels and putting it all back together.
Viola! it all fit the machine and each other perfectly and the front door binding ceased allowed them to close as expected.
In defense of the workers at @SuperATV who assembled these early hard cab enclosure kits, the panels are covered with the protective blue film that obscures the bends in the poly that make it all form fitting. I spent 6 hours second guessing myself thinking I was just not doing it correctly. Glad to find out for once, it wasn't me.
Now I explain all this in case some other poor bastards get a kit pre-assembled backwards like mine, 4 panels correctly and 4 panels transverse from what they should be.
Thing is you don't know until you get to the last steps of the instructions to see they don't line up.
Example: This picture is top front rear door where it meets the fixed panels. It juts out approximately 1".
20241122 180551
20241122 180559
After swapping the panels it now lines up and hugs the ROPS as such:
20241122 195314
280,769
How much did you have to trim?
This is how much I trimmed above the 4 doors. Used a Milwaukee Rotozip took about 10 minutes being careful.
20241123 100511
Here is how it all fits together bolted up after trimmed roof line.
20241123 130254
280,769
So everything buttoned up from the hard upper doors install as well as the @SuperATV rear bumper and hitch receiver. Only need to install the AJK throttle footrest, and the Bosman bumper with Viper V3 6K winch when they come in. I'ms tired of wrenching boss, but happy with how it turned out. Took it for a short spin and very impressed with the all around visibility out of the enclosure, especially when looking over your shoulder etc.
20241123 151417
20241123 151349
20241123 151232
20241123 151253
20241123 151308
20241123 151333
20241123 151436
20241123 151509
TripleB
TripleB
19,338
171,416
Caryville, Tennessee
View attachment 450628View attachment 450629View attachment 450630View attachment 450631
View attachment 450632View attachment 450633
Looks badass.
280,769
Going to give Alaska Side-by-Stuff kit a try, get the bottom gaps I haven't covered as well as the brake spring cover he makes. I think it will work with the triggershield material I already have on the back door gaps too.
Screenshot 20241207 225724 Facebook
280,769
Looks like it's Christmas at the Jackal compound this week.
Christmas again to pull that camper..........
20241207 115219
20241207 120828
20241207 172320
Oh ya Honda we needs a HUD too 😁
20241206 162414
Turns out dancing for gay truckers at Adult World pays pretty well 👌 👍 😆
280,769
