JayPo
Somewhat Well-Known Member
Not yetDid ya get a Packout cooler?
For my rear view mirror I hard wired a long usb cable to an auxbeam inputI have my tablet mounted up on the ROPS above the windshield. It is powered via a USB cable so I want to add a USB port up there somewhere. Anyone have any ideas on a good way to do this? All the USB ports I find are either rocker switch size or the ones designed to go into a round hole in the dash.
I'm more looking for mounting ideas for a USB port. I don't want a long USB cable routed from under the hood to the tablet because USB cables always go bad. I'll route the accessory 12V into some type of USB port (like this or this or this or something else?). I just can't figure a good way to mount any of these up there.For my rear view mirror I hard wired a long usb cable to an auxbeam input
Major General 2024 Talon 1000R-4 Build Thread
Power converter from 12v to 5v ordered with arrival on Thursday Just curious 🤔 why not wire it directly to the key-on 12V busbar or similar?hondasxs.com
I did this in my P1K5:I have my tablet mounted up on the ROPS above the windshield. It is powered via a USB cable so I want to add a USB port up there somewhere. Anyone have any ideas on a good way to do this? All the USB ports I find are either rocker switch size or the ones designed to go into a round hole in the dash.
I have a different Ram tablet mount that doesn't have a nice place to mount the housing like yours, but I might can rig something up similar. Thanks.I did this in my P1K5:
P1000 - Scoop's 2021 P1K5 Deluxe Phantom Camo Build
Spent a couple hours swapping the OEM springs on some new Fox QS3 fronts (3P) and rears (5P) with Viper linear rate springs (F: 250#/R: 300#). Would like to find time tomorrow to get them swapped out on the bike, but it's a busy weekend.hondasxs.com
I bought one of these for the housing and wiring only:
Attwood 11862-6 Universal 12V Cigarette Lighter Adapter Socket Outlet for Marine/RV with Mounting Kit, Black
... then swapped the 12V socket for one of those round USB charger sockets (the blades on the back are the same), then I mounted the housing directly to the back of RAM tablet holder.
POIDHFixed yet another rattle on the JAH. The drivers door rattled because it did not close tightly. I adjusted the door latch inside the door but there is not enough adjustment allowed to make the door close tight so it still rattles. So I put one of those round felt pads that goes on furniture feet on the door where it meets the rubber stopper on the unit. Door is now quiet.
There is a rubber bumper that you can adjust (turn in/out).Fixed yet another rattle on the JAH. The drivers door rattled because it did not close tightly. I adjusted the door latch inside the door but there is not enough adjustment allowed to make the door close tight so it still rattles. So I put one of those round felt pads that goes on furniture feet on the door where it meets the rubber stopper on the unit. Door is now quiet.
Thanks EMAW. I didn't realize that bumper was adjustable. I moved it out a little bit and no more door rattle 👍There is a rubber bumper that you can adjust (turn in/out).
I might have to do this mod tooThere is a rubber bumper that you can adjust (turn in/out).
