Sitting here drinking coffee thinking If the 1000 transmission is run electronically and voltage issues will burn up clutches, then why wouldn't of Honda put a stronger or larger charging system in them and run the clutch solenoids off of the charging system instead of the battery that way all the battery is for is initial startup. I do have the dual setup, think it's a good insurance idea all the way around. Just a thought. Figured you guys are a lot smarter than me on these things.
