P1000 Keeping water out of floor
sugarray
sugarray
Is this a game show?
661
1,257
WV
Has anyone tried to/blocked the front floor to keep the water out? Or lessen it? Looks to me there is a pretty big hole there and could reduce it some.
Reactions: CumminsPusher
drfubar
drfubar
TheDonFather
5,889
19,233
Mary's Ridge (Dayton Mtn), TN
That stupid hole by the brake master cylinder.
Why didn't they seal it up more then that?
Yes, something needs to be thought up to fix it.
Yea sealing the doors wouldn't help because it looks like a dam breaking where it comes through the firewall...OH and where the water comes over the dash when @Delton sprays me when we play in the creek. The mud and the water is half the fun, I can keep my feet dry in my truck... lol.
sugarray
sugarray
661
1,257
WV
I can wear my rubber boots too, but I don't always want to, especially if it's 100 degrees. I don't mind having wet feet, it would be nice for my tool bag not to get soaked. I like to keep it there for easy access. I'll look some over the next couple of days and see what I can come up with.
sugarray
sugarray
661
1,257
WV
Well, I put weather stripping around the lower joint there under the pedals, but no help. Water still poured in. I'm not able to pull all that off, but I've been thinking of spraying with FlexSeal. Thoughts?
Gator
Gator
The Most Unknown Member
2,476
10,399
Louisiana
FlexSeal... Yeah. That way if you want to mount a fan on the back and call it an airboat it will still float
Reactions: JACKAL and drfubar
sugarray
sugarray
661
1,257
WV
helpful, thanks
sharp
sharp
3,757
14,955
Tennessee
You could try using some type of rubber cut to fit tight and use the plastic push pins to hold it in. It won't be 100% but anything would be better than it is now. Just a thought.
GlockMeister
GlockMeister
The Bearded Wonder
7,604
35,569
Greenville, Mo
I figure anything you do to keep water out will probably just result in keeping more water in. just my 2 cents
sugarray
sugarray
661
1,257
WV
I tried to watch while crossing the river today. Water was at the bottom of the skid plates. Just pours in around that plate where the pedals are attached. I'm a little afraid of taking it all loose. I would like to put a rubber piece or weather stripping all the way around.
Reactions: GlockMeister
sugarray
sugarray
661
1,257
WV
My thoughts too, but I foresee having things in the floor from time to time and would like to try to make it a little drier.
drfubar
drfubar
TheDonFather
5,889
19,233
I don't think it's possible without hours of work and testing... Then like someone said it would keep everything in... It would never work for me cause I run all summer and way into the fall with my doors off. I hate being inclosed. Riding with @Delton and the rest of those Alabama / Tennessee hooligans is going to get you wet anyway.
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
Oh hush. You know you like it lol
Reactions: drfubar
Upstatefreedom
Upstatefreedom
224
410
Colton,New york
I've been thinking of trying to fab up something made of thin rubber (like tire tube). Think I can close off at least 75%. Just got to figure out how to attach it.
sugarray
sugarray
661
1,257
WV
Please post up what you figure out. I thought about using something like that, just not sure how to get it all around the pedal attachments and the opening.
sugarray
sugarray
661
1,257
WV
If you cover it up the best you can any water will flow out the big ass gap at the bottom of the doors just fine.
Sent from iPhone
What I thought as well. Runs out under the door just fine, but doesn't seem to pour in like around the pedals.
321,215
I'd seal this thing up good except for the door bottoms. The should almost tilt the floor slightly for quicker run out.
Reactions: sharp
