Lets talk Radios again... Pioneer takeover!
Willie_Makit
Willie_Makit
Stringbean
30
128
Fairview TN
Sorry if I missed this, but what GMRS or FRS channel, and PL Tone(privacy channel), will everyone be on? Does it matter by group?
Thanks in advance.
Reactions: Dp5hunter and sharp
Mudder
Mudder
NTC/TAP Transition Member
11,835
90,087
Baofeng copy? , lower price. Chirp recognizes it as a BF-F8HP, as posted on a local emergency preparedness group page. https://www.amazon.com/HESENATE-HT-...Hz-Transceiver/dp/B07G8Z1Y3M/?tag=sxsweb24-20
D73629B8 E70D 4722 A34C F06D6064978A
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
This is what I have found just for Your info, I just purchased the TYT Th8600 , got the program software loaded in the computer and the download from TYT But I did not use it because the Radio is unlocked now without pressing keys on startup I think that if you download the program from TYT into the radio it will lock those FRS channels then You have to take steps to unlock, TYT updated all of the downloads for th8600 in the last year , I just manually programmed channels into radio, It may be that radios manufactured after a certain date already have lockout, anyway I hope You can understand what I am trying to say here I may be wrong about all of it , I did not want to load program into radio to find out, it is easy enough to manually load channels into memory, Me and My Brother have been Hams for 25 yrs. And most radios designed for 2meter 70cm will not tx on those channels We have several icom and yaesu will not unless you modify, Special Thank You to @Ragnar406 , @Tramguage1 , @Mudder , Thanks For The Help Guys,,,,,
Do you have your Ham radio license to operate it....:D
HondaRed16
HondaRed16
258
501
Arizona
Can you put a booster on a cb in a sxs
No...not unless you absolutely added a second battery, dual battery separator, heavy gauge cable, etc. those amps pull a lot of juice.
You'd be way better off going the short wave radio route.
Tramguage1
Tramguage1
Texan
7,588
31,353
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
If someone was to purchase and program some Beofang handheld radios. How many would be interested in purchasing them at TO?
Think I can get the radios with external speaker/mic,antenna,charger and battery. I will preprogram them , I think I can keep them in the $50 to $60 range.
Also there are cheaper versions avalable. I think the ones with LCD screens would be more useful when doing local group rides.
K9Paco
K9Paco
648
2,328
Lake Charles, La
  1. Talon X LV
I’ve been looking into this for over a week now. I’ve debated it all. One minute I’m thinking that I need to take the Ham test and buy a good handheld or a head unit and the next I am really confused on all of this. I think that I’m just going to buy a good pair of the run of the mill walker talkies and then I’ll have two for later.
I wouldn’t mess around with walkies. Get a couple baofengs and program to the right channels.
Buy this and be done with it..
P1000 - Post your Black Friday / Cyber Monday sales HERE!
K9Paco
K9Paco
648
2,328
Lake Charles, La
  1. Talon X LV
I do value your input but it’s hard for me to get one of these units when all I would use it for would be for these group rides and that’s not going to happen but maybe once a year at best. I realize the bofangs are cheap and reliable but the risk of me handing one to another rider here locally that would maybe be riding with me and then not f*** it up with all of the buttons is high. And on top of that “I” don’t know how to use them. I just makes sense to me to buy a $50-$60 set of radios, communicate at the TO, then have more use for them other places.
Ragnar406
Ragnar406
The Great Bald One
4,460
17,084
Bella Vista, AR
There were three of us that got radios here locally to begin with - with every ride we do we convert others over to getting a radio. I have a couple extra handhelds that I will sometimes loan out and sure enough the person I loan them to will go out and get a radio the following week. Handhelds are fine and work for a small group of riders , mobiles are more convenient, as you don’t have to charge batteries and the range is better as they have higher wattage.
farmtimpioneer
farmtimpioneer
549
2,079
Brookville Ohio
If You order the TYT TH8600 make sure You order the TYT TH8600WP for water proof it is just a few dollars more but it has water proof plug They do have two different models,,, R&L in Hamilton OH.
