Lets talk Radios again... Pioneer takeover!
K9Paco
K9Paco
629
2,224
Lake Charles, La
  1. Talon X LV
Got my radio in. Haven’t put it in yet and probably won’t until after the first of the year. When I mount the antenna, does it have to be vertical or can I put it horizontal under my roof to protect it from trees and other objects?
Choogsbro
Choogsbro
CEO of Monkey Business
8,144
52,659
Monticello, Ky
Good question
It’s better if it’s vertical
Reactions: Dp5hunter
11,376
84,826
@K9Paco , Just be aware they do put out energy. Because I transmit at 25 watts for HAM use, I put mine about 2 feet away from seat due to RF energy, but that is likely overkill based on the limited transmission time (duty time). The radio can also be toggled to lower wattage, and best to transmit on the lowest wattage that works for close together talk. All that said, I just liked it on the front fender and put RTV silicone around it to minimize moisture inside the base. Go verticle.
BA5DB2A9 A3E8 42EE 8524 52A531CB4A0B 4DC0FBE5 8749 44F9 AD21 FE35260C3962
HondaRed16
HondaRed16
254
499
Arizona
If you mount horizontal you cut your transmission power by half and significantly reduce your receive range. You also are more prone to RF exposure.
Installing on the back corner or any corner lowered like that works but again if it’s not above the roof line you reduce as mentioned above. If you’re not trying to talk long range and want to communicate with the folks you’re riding with that will probably work. You are also steady cutting range with the small 1/4 antenna but again that’s fine for close range meaning not 5 - 10 miles.
I have put mine on the top corner and also the roof (on a sheet metal pie plate) with a magnetic mount so that it can be knocked off but not broke or lost (just a thought). I’ve also seen people hang them upside down from the roof but again you’re reducing.
let us know what you decide.
HondaRed16
HondaRed16
254
499
Arizona
Did your radio come with the program buttons on the mic or plane mic and the magnetic antenna?
K9Paco
K9Paco
629
2,224
Lake Charles, La
  1. Talon X LV
It’s the waterproof version of this one.
2b00a069477fce3cb7531c16de701c99
7,179
27,603
I added a flat plate to the center of my Slasher bumper. Then installed the magnetic base on that. I have only knocked it loose a couple times.
K9Paco
K9Paco
629
2,224
Lake Charles, La
  1. Talon X LV
I’ll probably just bolt on a small piece of meta to my roof and throw it up there. I like what you did and I’ll just put it back up when it gets knocked off.
11,376
84,826
I don’t understand any of that. What about here?
View attachment 170256View attachment 170257
Just sharing that RF energy off the antenna will be strong right beside your head every time you key the mic, especially at the H power (25 watts) - think like microwaves. This is a powerful HAM license level radio compared to camping walkie talkies. If you put the antenna right by your head, suggesting you use the lowest power output to reach who you are talking to. Just holdover thoughts from a career in Radiation Safety and being a HAM. Pushing the LO button will cycle between H, M, L power output, and in a line of sight group ride, the Low power might be good enough, even after passing through your head.
D919EFD9 474C 43A7 B1D4 A629684D81D3
HondaRed16
HondaRed16
254
499
Arizona
Thanks for the reply; In fear of being redundant there are several option versions of the TH8600 waterproof model on their website, the picture of the kit I think you bought shows it with a simple mic with no program buttons for $124.95. Did yours come with the the menu buttons on the microphone, the web picture shows it without?
See below:
TYT TH8600WPJTM2P
[TH8600WPJTM2P]
$124.95
Free Shipping on TH8600WPJTM2P
Free shipping to USA Only
Th8600wpjtm2p
Click to enlarge
PACKAGE OF TH8600WP AND 2M/70CM MAG MOUNT ANTENNA
This item is currently in stock.
TH8600WP
Small size 4 1/8" W x 1 3/4" H x 5 1/2" D
Water Proof
1750 hz tone
Automatic power off
200 programmable memory channels
CTCSS, DCS, 2tone, 5tone
Five programmable multi function keys
HondaRed16
HondaRed16
254
499
Arizona
See below:
TYT TH8600WPJTM2P
[TH8600WPJTM2P]
$124.95
169484 3e4b9f12db3309335e5aa12c4982062a
Click to enlarge
TH8600WP
Water Proof
1750 hz tone
Automatic power off
HondaRed16
HondaRed16
254
499
Arizona
I'd suggest to try not to do that please. You never want to penetrate the roof if you can avoid it. Just get you some good metal to plastic adhesive, make sure you clean your bonding area good with something like PVC primer.
Also if you can ground the metal plate to the frame (it's not absolutley necessary but you will get better performance and longer life out of the radio (nothing is simple with toys LOL).
K9Paco
K9Paco
629
2,224
Lake Charles, La
  1. Talon X LV
It is this radio for this price but it came with the antenna that is in your other picture. It was a Cyber Monday deal.
E3890a71b711a974bc1240230933c218
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
I got this flexible antenna at R&L Electronics in Hamilton Oh. It seems to be very durable and flexible like a rubber ducky,,,,
UPDATE DONT BUY THIS ANTENNA CANNOT GET GOOD SWR !!!!!
IMG 20191213 191131373
IMG 20191213 191212035
IMG 20191213 191332472
HondaRed16
HondaRed16
254
499
Arizona
View attachment 170396 View attachment 170397 View attachment 170398
Yes that works as well. It all works.
Basically the shorter the antenna the shorter your transmit and receive range.
So if you just want to keep up with the group & they’re close by and you don’t need to talk long distance to base camp or other riders farther away...the short antennas can work ok.
We could spend a very long time talking about setting the SWR, the best antenna and where to mount...but not a big deal if you’re not like some of us older radio dudes that wants everything correct for the best solution and optimum performance.
The neat thing about these HAM/FRS/GMRS radios is the worst setup will out perform and are way more clear than the best CB setup :)
Ragnar406
Ragnar406
The Great Bald One
4,446
17,020
Bella Vista, AR
I started out with that antenna, I never could get it to an acceptable SWR on my Honda where I have mine mounted so ended up not using. I loaned it out to another rider at takeover when they least their antenna and because they had mounted on/ near roof line it was snapped off pretty quick when they went into a trail with some trees hanging over.
