Lets talk Radios again... Pioneer takeover!
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
I started out with that antenna, I never could get it to an acceptable SWR on my Honda where I have mine mounted so ended up not using. I loaned it out to another rider at takeover when they least their antenna and because they had mounted on/ near roof line it was snapped off pretty quick when they went into a trail with some trees hanging over.
I have not mounted the antenna yet or even tried it, that sounds discouraging :( , when I was down at R&L I was telling Roger what I was going to do with antenna and that is what He come up with up to that point I had never seen a 2meter dual band like that one,,,
Reactions: Dp5hunter
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
I would still try it out, I tried mine early on and it could have been I got a faulty antenna - I seem to remember putting the meter to it and consistently getting an open connection -
If someone was sure they were only going to use the FRS and GMRS freq they could go with a UHF antenna and have a shorter profile with no ground plane needed at all.
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
Here is where and how I mounted my antenna - I have only lost one and have driven in quite a few tight trails .. I do carry an extra just in case
F0A82C44 646E 478C A7A0 5C171709898E 27EBD377 7152 4760 B7D7 79E4B1761570
I made a clamp/bracket for mine... after I tore one up, in the upright position, I flipped it and run it inverted now. I’ve still broken a couple. I would just get the RB3 antenna mount and carry a spare antenna. Or if you have a bumper like the TC you can run a magnetic mount. I have one, but haven’t tried it yet.
CC2EDEC6 C10A 4136 A746 1854555ADAEA
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
That is what I would have done - if I did not run Led Whips
HondaRed16
HondaRed16
258
501
Arizona
That's a nice setup, a little bit above the roof line to get some signal out but low enough it shouldn't snag on anything much.
In addition to others that have posted good option antenna's here's a few that work well if this is allowed:
https://www.amazon.com/Antenna-Base-load-Magnetic-Baofeng-TALKCOOP/dp/B01MQT044S/?tag=sxsweb24-20
https://www.amazon.com/Tram-Amateur-Hi-Gain-Hi-Power-Antenna/dp/B00TY2KRE4/?tag=sxsweb24-20
https://www.amazon.com/TRAM-10280-Dual-Band-Pre-Tuned-Amateur/dp/B07BBPWM8K/?tag=sxsweb24-20
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
what kind of radios are common on these trips cause i have vhf i could strap on the bike fairly easy. i have no clue on frequencies but i do have a 102 inch whip with spring on my bike from when i used to have a cb on it. it taps red lights when i trailer under them.
7,593
31,391
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Most of the core members have the TYT- 8600. I also have a couple GT3 Baofang handhelds. I have a listing of the frequencies somewhere. I'll look for them.
Reactions: TimG
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
there is 14 at the top of this. i seen after i posted that. not really into buying a 100 dollar radio for 3 days a yr. use. although i did see some hand helds for cheap like 30 bucks for the tyt type
Reactions: Tramguage1
Choogsbro
Choogsbro
CEO of Monkey Business
8,144
52,659
Monticello, Ky
I replaced my Kenwood with a TYT-8600. I will be posting the Kenwood for sale with antenna. Just need the antenna cable. I'm thinking $75.
IMG 0790
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
I believe not
might have to see. not sure what the plug looks like but if it can be swapped over my antenna has been on my bike for 5 yrs and never had a problem with it breaking. on limbs over the top of the bike. but it has slapped the front bumper a few times
