P500 Lightbar mount question
rocmar
rocmar
4,741
5,778
4 CORNERS
My windshield & roof
clamp down with Honda
clamps... ( work great )
my light is bolted...
rocmar
rocmar
4,741
5,778
4 CORNERS
Just looked.....
see wat ya mean
rocmar
rocmar
4,741
5,778
4 CORNERS
Think Jak has a pic on here somewhere
...that shows a threaded rod ( not sure the size )
Going end to end...with nuts on each end
Reactions: Jshell3
I know lots of riders
that have had problems
with big light bars being
Loose....vibration.....
rattling loose..
I'm just saying...
I went with smaller
because of that.
threaded bar from end to end
seem to help
I'm doing the HID bulbs in the factory housings and recessed led's in my strong made bumper, like @Stacy did and two led cubes on each corner of the roof attached to the roll bars for rear cargo and back up lights (I bought brackets like jshell3 for them). I'm thinking that will all be sufficient. But i have to see how the roof and windshield go together before I can even think about a light bar up top.
Reactions: rocmar
Jshell3
Not trying to get in your
business. ..I would go with
a better quality clamps
...to keep from having
issues later
From what I saw today, these clamps are well made. I think they will also allow me to push the lightbar out further from my crossbar that I'm mounting it to. The Honda roof has about 8-9" of overhang from the crossbar it clamps to.
So my concern is a bright bright LED lightbar being under roof too deeply.
I would almost go top mount, but given the tree limbs and what knot.
My aim is to give as much under roof protection, without cutting my field of vision, or blinding myself from reflection.
I promise to report the ridgitity of the mounts. But basically, it's all metal... so what's not to like?
Reactions: JTW
rocmar
rocmar
4,741
5,778
4 CORNERS
It's the span of the light bar
with no support in the middle
it's your deal bro...
I was just sharing
wat I seen...
Jshell3
I was just sharing
wat I seen...
The all thread 1/4 nut you eluded to has no middle support.
So I don't really see a difference mounting this way.
But if it needs a little something extra, I'm sure I'll come up with something. :)
Reactions: JTW
rocmar
rocmar
4,741
5,778
4 CORNERS
I think it would fit there
rocmar
rocmar
4,741
5,778
4 CORNERS
The stiffness of threaded
rod...is your support
Jshell3
I was just sharing
wat I seen...
I see what you're sayin, now.
Yeah, if the clamps "move" then the hanging lightbar will drop out of the end bolts.
I may go ahead and add the prevent 1/4" all thread rod.
Won't hurt.
Definitely cheap insurance.
rocmar
rocmar
4,741
5,778
4 CORNERS
Won't hurt.
I'm more than sure
You'll finger it out
....let see some pics
Reactions: JTW
Longbrake500
Longbrake500
96
168
Anna Ohio
I have similar mounts for my light bar if not the same ones.. Issue I had with them is the bracket that comes with them is not knurled like the bracket on the light bar so it would not hold it securely in position. So I used the bracket that came with the light and just the bar clamp portion of those brackets. I will grab a couple pics of how I set mine up. So far it is holding up and solid as a rock.
Reactions: JTW
Longbrake500
Longbrake500
96
168
Anna Ohio
Here is how I mounted mine up.. I took off the L bracket that came with the clamps. The bar clamps actually worked out perfect where they were flush with the roof so I just drilled through the roof and used the brackets that came with the light bar and mounted it down to those clamps.
Full
Full
jak9922
jak9922
hot headed wopolock
3,283
5,636
pittstown ny
i see what you did there now thats a smart move i like your set up
Reactions: JTW
196,182
I mounted my 22" right to the plastic roof with the hardware supplied. It has came loose once and was hanging from one bolt.
Not the ones through the roof though, the ones that screw into the bar. It does take a beatin' up there.Front Latest
Reactions: Jshell3 and rocmar
rocmar
rocmar
4,741
5,778
4 CORNERS
Not the ones through the roof though, the ones that screw into the bar. It does take a beatin' up there.View attachment 23203
I can say...that's been
most of wat I
have seen out riding
....guys trying to wire
there light bar on...
cause bolts are gone
the threaded bar helps
Reactions: jak9922
