P1000 Lightbar Wiring Harness
Mvalerio89
6
Florida
I purchased a lightbar and wiring harness. The harness connects directly to the battery and has power all the time. Is there a way to wire the harness to where it only gets power when I turn the key on?
Reactions: TxDoc
63,620
What does the pre-wired switch look like?
Sometimes.
You can snip the trigger wire and hook it to a key-on source.
Mvalerio89
6
Florida
Sometimes.
37D5BE5D 1F12 42E2 9151 597E5B4E8B18
63,620
Ya.. idk.
But concept is still the same though.
1 hot wire.
1 trigger wire out.
1 ground wire.
IvanGirderboot
IvanGirderboot
16
59
Greater Denver Area, CO
Is that a Rough Country/Cree light bar switch? As others have said, you just need to grab ACCY (Key-On) power and then run the light bar through a relay that's controlled by the Key-On power. You'll want to use a relay because the ACCY circuit is shared with other items and is limited current. For a standard automotive relay, the wiring would be as follows:
  • remove the light bar positive connection and connect it to 87
  • connect the battery to 30
  • connect ground and key-on accy power to 86 and 87 (either way)
  • (If the relay has am 87a terminal , it will not be used)
A detailed write up about relays with lots of pictures can be found at this page, if you're looking for more info.
Reactions: Mvalerio89
Hillbillytnt
Hillbillytnt
518
1,902
Ky
Does this plug into another harness running to your relay. If they are black blue and white like most eBay harness then you need a five pin switch.
