P500 Loading into my F150 bed
  • Thread starter Deleted member 3748
  • Start date
Deleted member 3748
This was my first attempt at loading my Pioneer 500 into my truck bed. I went slow and it was easy. I put the spare tire from my trailer against the front of the box to keep me from blowing out the rear window. :D No more trailer for me.
BTW - I'm installing air springs this weekend to level the rear.
156,797
Are you just riding on the tailgate cables or do you have the DG supports?
105,591
Good job! You'll love the air bags. My dad use to say he had an old bag! Whatever that means lol
HUCK
HUCK
1,047
2,315
ARIZONA
Just the cables. The extra supports are only needed for Chevys and Dodge. Right, @Remington ?
You would spend our money better to get the supports . If your f150 isnt clapped out there is no reason for air . A friend of mine hauls his all over in Ram 1500 (with gate supports) and has no problems at all . It is an f150= 1/2 ton = p500 don't weigh that much .
Reactions: sharp
105,591
He has the air for the stabilization from the the machine being too heavy above the cab. Up in northern michigan especially when crossing the MAC bridge (if too high they shut it down), winds can be treacherous. The extra stabilization and control no matter the truck is nice and much safer
Deleted member 3748
Besides stabilizing the load, I have a lift in the front to level the truck and when I load the back the headlights point up.
And the tailgate supports don't add any strength to the tailgate, they just won't break like the cables could. I considered it, but if you think about it... I have 500 lbs on the tailgate. That's two 250 lb guys sitting on it. If that snapped the cables or bent the tailgate I'd be really surprised.
O
oldfortyfive
595
1,316
Illinois
That's static loading. Going down the road adds dynamic loading, which can be drastically higher.
105,591
I think I had 600 lbs easily on mine an multiple times this weekend with the 3' in diameter wet maple logs I cut, plus that dam tailgate step and bar. The tailgate weighs a ton when I take it off for my 5th wheel gate. Have to go to the chiropractor after removal lol. Yes those cables should hold as long as there not cut or rusted. There the same factory part number for the superdutys.
105,591
wait a minute.....you must be an engineer? That's technical terms there! Lol my neighbor is one and throws that foreign language around (for those of us In Reo Linda)like a baseball! Lol :)
156,797
I have Air Lift bags on mine, they're made in Michigan and guaranteed for life. Installed them in March and put 60 lbs in them for pulling the travel trailer. They're still at 60 lbs and they work. I have DG supports for my Sierra that I've never used but they won't fit that Ford.
HUCK
HUCK
1,047
2,315
ARIZONA
Good point ! I have the supports BUT I have never heard of any tailgate straps breaking for any reason . All the old guys that I ride with have them and recommended them . I bought them so I wouldn't be hearing WE TOLD YOU SO . Better to close the gate before the cows get out .
Deleted member 3748
You guys got me thinking about it again. IF one of the cables did break, it would be a real problem. And $50 is cheap insurance, which isn't a much money when you consider what I paid for ramps and air springs.
Deleted member 3748
Did you give up hauling it in the bed?
105,591
The way you have it now is 10 times safer than the trailer set up you had before! Lol
I'd use a real heavy wide yellow strap from the inside front of the bed and then around the back of the machine to the other side inside( should be doing that anyway for extra security) that would also take some of the weight off your gate if your still worried. Cheep and easy! I'm sure someone will have something to say that I'm not scientifically correct lol. o_O
Deleted member 3748
My trailer is just fine! It was being too short that was the problem. SxSs have to be strapped on all four corners per the law. I'll pull the bulk of the load towards the front and just enough in the back to keep it from bouncing.
I'm not worried about the tailgate, but I am driving a 10 y/o truck. I can't afford a new Superduty every two years like you millionaires. ;) And with as much money as we blow on these machines, it's nothing to spend another $50 to make unbreakable tailgate supports.
105,591
Understood
