P500 Long term Kenda HTR Radial insights needed.
JCart
JCart
897
2,024
Kamloops, BC Canada.
Hey Guys looking to purchase the Kenda HTR Radials and was thinking in 26x11x12s or possibly the 27s for all corners and mount on my 5-2 x12 Rims. Looking for insights, wear performance and size you run on your 500. Currently running AMS Slingshots in 26x11x12 and they have been an excellent tire, wear like iron and are a great all round tire. They are down (guessing 50-60 %) and have 3000 Kms plus on them, I’d get another set, but wanna try radials. True mounted size would be handy to know as well as many are undersized. The Slingshots run true 26” diameter and are 10.5 mounted and the gear ratio seems just about right to me running basically stock engine.
TIA,
j
highpocks
36
29
prescott mi
TIA,
j
jcart i have 27x9x12 on all 4 corners kenda bearclaw htr and i love them so far on the front i notice a little rub but nothing serious i have the 5-2 off set wheels i gained 2 in. ground clerance with this set up hope this helps you
ehart814
ehart814
1,654
3,643
NWPA
I run htrs 26x9x12’s all around on my 500. Appx 2200 miles on them and the tread is at around 50-60%.
JCart
JCart
897
2,024
So I ended up with 27”by 11” by 12s on 5-2 rims, they do touch on the front (just) at almost full lock and compressed a bit. It’s just on a push pin for my front mud flaps. Not ridden a whole lot in the last year new nubs are barely worn off. I will say I’m super pleased with the Kenda HTRs, so smooth, great traction in snow, wet dirt and mix of trail and gravel roads @ 5-6 psi. Not had the opportunity for any hard core mud yet. I did install Elka Stage 3s last year too and as a combo, I’m really impressed. Easily can run in 1 to 2 gears higher then stock. Have only fully bottomed out a couple time and I’ve not adjusted from factory setting. I’d say to improve ride get radials first, then Elkas second as the radials make a significant improvement. I might try re installing my anti sway as I notice on corner carrying speed it’s not as solid in the corners now. Appreciate all the comments and inputs from a year ago.
Cheers,
156,461
Cheers,
It's because of the wide front tires. I'm experiencing the same thing and have slowed way down in the corners. It's a little better now running higher PSI in the fronts. I'm okay with it, not really a drifting type machine anyway and this thing's a beast when it comes to crawling in sketchy sh**. Mine are 26 x 11's and don't rub at all with 5+2 offset, had 1" spacers on it too and it rubbed bad.
JCart
JCart
897
2,024
I’ll give that a whirl and play with front air pressure thanks for the input trigger. It’s not that it’s terrible, just would like to tighten up the drift feeling a titch. And you’re correct they are little beasts heh heh.
Thanks again.
j
