P1000 Looking for black friday skid plate deal
906UP
906UP
13,164
123,033
da Yoop
For the same coverage area as the SATV (does not include A-Arms), Ricochet has all aluminum 3/16" 5052-H32 Aluminum for $1050 or 3/16" Aluminum with 1/4" UHMW overlay for $1475.
The hybrid set is what @aprils_fool put on his P1K5, I went with Ricochet for the sole reason that, at the time, they were the only one who made a set that didn't use self-tappers or put extra holes in the frame. That was a definite deal breaker for me. I also went with alum because, IMO, it's better suited for where I ride most of the time, the UP of Mich. I did have a pretty good dent in one after last years trip to T.O. but a BFH took care of that when I got home.
Robobrainiac
Robobrainiac
2,472
8,643
I just ordered my SuperATV skid this evening. I have the high lifter arms and the clearance is awesome. I would recommend getting the SuperATV ones. The tire size option and clearance is worth it.
Usmc3468
Usmc3468
Greenwood, Indiana
I just got my SATV skid plate and I am currently installing it. There are a few issues with the holes lining up that has caused me lots of frustration. The most notable is the middle bracket has to be elongated to reach both holes. Now I am dealing with all the self tapping screws.... I feel like I am turning the underneth into swiss cheese. Lol Either way it is a solid unit I just wish is utilized more of the stock holes.
Reactions: Scoop and Coeus
BlownCJ
231
Northwest Florida
Semper Fi brother.
I ordered mine too and think if there is room I am going to use riv nuts and their washers with tractor supply grade 8 hardware and lock washers. Grade 8 stuff from tractor supply is sold by the pound so you dont feel like you getting butt*****ed
SH21
SH21
114
605
NH
Does anyone who has or had the SATV skid plate care to comment? Would you do it again? What did or didn't you like about it?
I have the SATV skid plate, and I would do it again.
Install was straight forward, some existing bolt holes are used while others/new ones are self tappers. I did predrill the self tappers first to make installation while holding the skid up with the other hand easier. Took two of us less than half a day, with beer breaks, to install.
Bounced off a rock this weekend while riding and the machine and skid plate are now worse for wear. Honda should be ashamed of themselves to call what is put on from the factory a skid plate.
Reactions: Scoop and SuperATV
Coeus
Coeus
Major General
59,779
597,006
Signal Mountain, TN
  2. Talon R4 LV
Semper Fi brother.
Let me know how that works out… received mine and that is in the list for sometime this year
Reactions: Usmc3468 and Scoop
tdhanses
tdhanses
1,044
3,553
Kansas
Make sure you leave everything loose so you can line it up and pre drill the self tappers.
bumperm
bumperm
1,851
6,658
Gardnerville, NV
I would think rivet nuts would be the way to go. Much stronger, cleaner, and easier to fix if damaged than self tapping screws. If you don't already have a rivnut tool. $50 gets this set with an extensive selection of mandrels:
I used it to attach my upper light bar brackets.
20210804 222122
20210804 220255
Usmc3468
Usmc3468
Greenwood, Indiana
Well I finally got mine installed. That was definitely harder then I thought. I was not able to lay mine on it’s side so I put it up on ramps. I did end up stripping one self tap hole so I’ll need to get a bigger screw maybe. I do like how thick it is but for the price I wish it had a better fastening system. I have several SATV parts and this is the only one I am less then impressed with. I worry these screws will work loose over time. I will definitely look at the rivnut idea once my arms regain feeling. Lol
Coeus
Coeus
Major General
59,779
597,006
Signal Mountain, TN
  2. Talon R4 LV
I think the self tappers will be interesting for those that drop their skids for oil changes… I think that is my worry…
tdhanses
tdhanses
1,044
3,553
Kansas
I installed mine just as it sits, pre drilling made a big diff I think but all of the skid plates pretty much use self tapping screws.
Overall they have held just fine but i’ve also considered rivet nuts but so far haven’t lost a single bolt either.
Coeus
Coeus
Major General
59,779
597,006
Signal Mountain, TN
  2. Talon R4 LV
Have you tried to remove the skid at all?
Scoop
Scoop
4,261
15,961
  3. Talon R LV
The Trail Armor skids use some self-tapping screws, but they also use a good number of the factory bolts.
906UP
906UP
13,164
123,033
da Yoop
Ricochet has a 15% off Black Friday sale on orders over $150, their skids don't use self tapping screws, either factory holes or clamps.
