P1000 Mictuning Dual Volt Meters......Problems?
nitzo
nitzo
521
1,105
East Coast, Florida
Has anyone had issues with these, I'm on my third one. The top meter works perfectly, it's the bottom one, it will read a constant 5 to 8 volts, then when I turn it on it will add the 12 to 14 volts so it reads around 19 volts..........
Dualvolt
MICTUNING LED Digital Double Voltmeter, Round Panel Voltage Monitor Blue for Car Pickup RV Truck Dual Battery Pack
by MICTUNING
Price: $12.98
Vikes79
Vikes79
SKOL!
10,884
105,584
South Dakota
  2. Talon X4 LV
by MICTUNING
Price: $12.98
I have the same ones. I have them on some ice fishing boxes and on my p1000.
No issues whatsoever.
Have you verified the readings with a meter?
nitzo
nitzo
521
1,105
East Coast, Florida
Yes I have.
I think its a water intrusion issue. One went bad after washing the pioneer the other after a hard rain. Still, they should be better than that I believe.
Reactions: adnoh
BBLASER
159
277
Phoenix
I am pretty sure that is the same one I have, I have yet to have an issue with it after a year. I spray the inside of my cab with water every time I wash it, no problems yet.
Odd... I’ve washed the s*** out of mine and never had an issue.
nitzo
nitzo
521
1,105
East Coast, Florida
It is water. I made up some jumpers and wired it direct so I was sure I didn't have a bad connection somewhere. I still got the bad readings so I took my heat gun and dried it out and watched as I was heating it the readings came back down to where they were supposed to be. Who would have thought ? Huh.
Reactions: adnoh
adnoh
adnoh
106
115
Yes I have.
Same here, had problems everytime i washed it. I replaced it with another one , same brand , and never had a problem again
BBLASER
159
277
Phoenix
Holy hell, what is in your water? haha. At what point do you try and get a different brand.
ToddACimer
ToddACimer
Pioneer 1005-2
3,559
14,601
Oshkosh, Wi
Both of my Mictuning volt meters started on fire in the dash. I'll never buy their products again
63,552
When I can find another round dual one.
I have several in several colors in stock. But like the others, they failed the water test. So I havent listed then.
Some clear silicone might fix them right up.
I'd sell you some for $5 each + shipping if you want to try.
nitzo
nitzo
521
1,105
East Coast, Florida
Thanks but nope. ToddACimer's post and the problems I've had are enough for me to cut the strings on anything Mictuning.
