P1000 mjn's build thread
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
Look what showed up today! :)
Greg does awesome work! All the script is LED backlit in red.
Hopefully I can find the time to get it installed this weekend.
IMG 3622 IMG 3623 2
mjn
mjn
1,409
5,206
Looks good can't wait to see it in
It depends on how many, and what type of switches you want in the panel, but rough #'s are between 250 & 300 bucks. He sends it with a complete breakdown of what wire goes where, even a template to put on the dash to cut it out properly.
It's not cheap, but he does absolutely top notch work.
mjn
mjn
1,409
5,206
Well... this week should be busy.
My better half is headed for San Diego, so my "honey do" list will be much shorter.. :)
The plan is;
*Install the Concours Specialties panel
*Install the second battery/isolator/bussbar/fusebox/etc... provided all the parts get here in time.
*I dropped off all the aluminum for my bed sides at my buddys shop. Hopefully he can get the pieces cut, and maybe even welded together. We'll see.. I'd love to test fit the pieces so I can get 'em off to my friend to powder coat.
Wish me luck! Hahaha!!
mjn
mjn
1,409
5,206
The panel is in and hooked up, all the parts for the aux battery are set up and ready to install this evening.
@OnTheJob , question for ya;
I’m putting the Stinger in the same place you did, but it appears there must be some wires right under the spot where I’m screwing it down.. I can’t seem to figure out what the heck is there..did you hit anything while screwing it down?
381BFF2A 9124 4FC2 B558 6D02E059B6F0
Wish Id known about him when I bought my 1000 that is SLICK !
BWAF
BWAF
I get paid to pass gas
8,869
42,495
Carthage MO
Dam that looks good love the back light
OnTheJob
OnTheJob
426
925
Bristol, NY
Looks awesome! Very impressive.
I forget how I checked under there but I don't remember seeing anything. I just used short little self tapping SS screws to anchor it down. What do you think you see under there? I'll have to double check when I get home on Thursday
mjn
mjn
1,409
5,206
LOL! I really don’t know.. I just see the end of a cable holder loop sticking up right under where the stinger goes.. I’ll look a little closer tonite when I mount it.
Reactions: BWAF
mjn
mjn
1,409
5,206
Thanks for the comments guys, I think it looks kickazz for sure.
I know it’s not cheap, but when he does a panel, it comes DONE.
The winch switches are tied together, & the wire harness is plenty long, and comes with a simple list of what goes where.
I have a ground, a key on power wire, & then a wire for each switch. Simple stuff.
Hey, believe me.. if I can figure it out, anyone can!
mjn
mjn
1,409
5,206
The limited edition script was my idea, but I’ll bet he could put whatever you wanted in there..
Reactions: BWAF
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
What's his phone number?
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Considering you have over $150 in parts and I spent several hours building my last one this is the way I'm going for sure.
Save yourself lol...fixing to build my new one
Reactions: BWAF
Similar threads
Replies
Views
438
P1K5Dave
V
Replies
22
Views
2K
Jankyeye
Replies
65
Views
7K
P
Replies
Views
3K
