P1000 mjn's build thread
mjn
mjn
1,409
5,206
SE Washington State/N Idaho
Installed the steering wheel this morning. Thanks to CP, the install was easy.
couple of notes;
*The accordion piece from the other cheap kit works perfectly, but it does need a small amount of trimming to fit properly. Easy stuff.
*I now see why CP said it trimmed the top of the steering shaft.. can't fit the horn button on. Not sure what I'm gonna do here. I'm not all that jazzed about trimming the top of the shaft down, but we'll see.
*inexpensive steering wheels come with cheapassed screws. I stripped out the allen top on one of 'em just tightening it down. Crap. Gonna go to the parts store tomorrow & get 6 quality screws to replace them.
Other than the gaping hole where the button goes, it looks good!
IMG 3838
IMG 3839
couple of notes;
I love that wheel!
I think I forgot to mention add a steering wheel horn spacer will allow you not to cut the shaft. I’ll find it
One like this
58A0D6F9 706A 45DC BDC2 F2CA0BABFA96
Install under horn button
mjn
mjn
1,409
5,206
I love that wheel!
One like this
Right on brother! That is exactly what I need. Gonna order that sucker right now.
**Edit; DONE.
mjn
mjn
1,409
5,206
ECD250F6 A9AA 4AFA 925C AC3B6977EB1D
82C0CD04 51C7 4EF2 A2DA 7479E1A90880
Spent some time working on the bed sides today. Got most of the holes drilled and test fit.
It’s coming together pretty good! Still have some grinding & smoothing to do before I send em off for powder coat.
I can’t decide if I’m gonna powder coat the saw press or not...
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
couple of notes;
I really like that steering wheel. Would you mind posting a link for it? What other parts do I need @CumminsPusher
@mjn do you remember what thread that was with all correct parts?
mjn
mjn
1,409
5,206
I finally got around to putting a pair of cubes on for backup lights. Had them on the Viking & they work great. For the P1K, I utilized a hole in the back side of the roll bar to attach a short piece of flat bar for mounting. I was able to put them right where I wanted.
IMG 3978
IMG 3977
IMG 3977
mjn
mjn
1,409
5,206
B4662D34 8C82 42A5 BA2A FB647E0AF3A6
86323B89 B32F 4A77 B825 8D15BB7E1A75
I decided to make use of the 24” dual row Rigid bar I took off the Viking. I was gonna do the 52” across the lower windshield... and still may sometime. For now though, this one will work fine.
I looked at a couple different ways to mount it, and came up with this today.
A severely tweaked pair of short bars I had in my toolbox, bolted to a bar clamp.
Looks kinda ghetto right now, & I do have a little more tweaking to do on one of em...
But here it is.
mjn
mjn
1,409
5,206
I can get it about 2” lower, and I think I might do that.
Also have to find some shorter bolts & loose the washers lol!
BWAF
BWAF
I get paid to pass gas
8,869
42,495
Carthage MO
mjn
mjn
1,409
5,206
Well, it’s been a busy week!
Spent a few days at Barrett-Jackson last week, so I was determined to make some progress on my days off this week.
Hooked up the Rigid 24” light yesterday.. I’m still going to replace those mounts, but for now, they work.
Reactions: BWAF
mjn
mjn
1,409
5,206
Put 6, 1/4” bolts on the bedside, and 4 across the top. That should be more than enough to properly hold it together.
I’ve decided not to powdercoat the saw press, but am
90E8963B 7529 4194 9DF6 0376A9FAACB0
working on an aluminum plate to cover this ugliness..
mjn
mjn
1,409
5,206
Okay, today I finished installing all the jack-nuts for both sides of the bed. Also drilled all the holes along the sides to hook straps or bungies into.
All that’s left is a little more welding, and powdercoat.
I paid special attention to the side that will have the saw press on it, by putting 8 jack nuts in the side, and 4 across the top. The other side just has 4 in the side, and 4 across the top.
mjn
mjn
1,409
5,206
5A3E053F E01E 4918 8277 652EF25E62D5
The other little item I tackled today is the constant rattle I get at idle coming from the passenger door.
The rattle is not from the hinges, it’s from the trim panel bolted to the outside of the door.
I took it off, & wrapped the 4 plastic studs with duct tape, leaving about a half inch or more sticking up. Put the panel back on... and no more rattle.
Similar threads
Replies
Views
471
P1K5Dave
V
Replies
22
Views
2K
Jankyeye
Replies
65
Views
7K
P
Replies
Views
3K
