swsebek
A 2” lift is as big as you can go. If you Jack the sxs up with a 3 inch lift you can here the axle popping and binding but with a 2” like this one from strong made it does not.Very simple to install. I will note that super ATV did not have the arched arms till recently or I may have went that route.I had the 2"strong made bracket lift on my 700. It was very well built. The newer models (I think 2017 and up) are just spring spacers and they definitely make the springs stiffer. I do not recommend the strongmade bracket lift. I know some people love it but my tires rubbed worse with it than with no lift.
