P700 More ground clearance
swsebek
swsebek
2,854
5,835
pa
I had the 2"strong made bracket lift on my 700. It was very well built. The newer models (I think 2017 and up) are just spring spacers and they definitely make the springs stiffer. I do not recommend the strongmade bracket lift. I know some people love it but my tires rubbed worse with it than with no lift.
A 2” lift is as big as you can go. If you Jack the sxs up with a 3 inch lift you can here the axle popping and binding but with a 2” like this one from strong made it does not.Very simple to install. I will note that super ATV did not have the arched arms till recently or I may have went that route.
BBC6EDD8 74BE 44DA ADDF FECF1322E0F1 7E243B61 A831 409F ACC2 25A6BD0CD635 DD7335F1 5757 4D90 8EA6 4E5E1DB2A11D
Reactions: Backwoods
WagginTail
WagginTail
1,656
6,075
SC
A 2” lift is as big as you can go. If you Jack the sxs up with a 3 inch lift you can here the axle popping and binding but with a 2” like this one from super ATV it does not.Bery simple to install. I will note that super ATV did not have the arched arms till recently or I may have went that route.
View attachment 320043 View attachment 320044 View attachment 320045
That's the strong made lift. I didn't have good luck with it. It acted like a lowering kit for me. Glad it works for you though. I went through a lot of trial and error(mostly error) when I was trying to figure all that out. The super ATV lift mounted to the top of the shocks.
swsebek
swsebek
2,854
5,835
pa
Man!!!! You are right. I could have sworn I ordered all my stuff from them in 2014. I have got to look at the pics before posting🤦🏻
Catch5060708
Catch5060708
10
Alabama
Looks good. I like those wheels. So to answer your original question... I would go with arched a arms, fox shocks and 27" tires. And get a good uhmw skid plate. I'm getting ready to put the arms and shocks on my 1000. Just waiting on my front shocks to come in.
Dumb question… do the arched a arms lift the entire machine or is that just giving you more ground clearance on your a arms?
