P1000 My forever trailer
Jshell3
I spent the afternoon thinking about how to pull BB the 8 hrs to the Takeover...
This is what I came up with.
Started w 1/2" D rings and 3/8 carriage head bolts. Lock washers.
IMG 4869
Pop a chalk line over the nearest angle iron brace to the rear tires...
IMG 4870
IMG 4871
Try to burn your drills up.
IMG 4876
Be a little lucky...
IMG 4879
BAM!!!
IMG 4888
Try as hard as you can to figure out how to best use your new tie down anchors...
IMG 4890
IMG 4893
Buy some REALLY stout ratchets for the front.
IMG 4894
IMG 4902
Finish the entire project a full hour after dark?!? I got hung up on the rear chain.
Anyways, if any of you haulers would like to offer suggestions, or things that you bind a little different, I'm all ears!!!
As of now, this is my set-up!
Cheers
Tramguage1
Tramguage1
Texan
7,478
30,587
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Can you use a couple ratchet straps on the rear instead of the chain? I be concerned that if the machine bounces the chain could come unhooked.
X4Dice
X4Dice
87
130
USA
178,877
Only thing I could see is the front straps being cut by what they're wrapped around on the trailer... I can't tell exactly from the pic if that's a concern. I don't like my strap webbing touching anything.
Me either, cut one of mine bringing the Pioneer home the first time.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Maybe wrap a strap just outside the Y on the rear roll bar and take it diagonal to the furthest anchor. Do both corners to make an X .......
There's several ways to skin a cat. As long as it is still on the trailer when you get there you have won the battle!
Reactions: sharp and Jshell3
Jshell3
I spent a lot of money on that stupid chain. Lol
It's too big for everything.
But it does have those spring loaded closures to keep it from unhooking. (From the Drings, anyways)
Jshell3
I second that
I need to weld an iron loop to hook to.
Reactions: sharp
And ideally you want your rear straps or chain pulling the machine backwards... but I understand if you have room constraints limiting ideal angles.
Reactions: swsebek
Tramguage1
Tramguage1
Texan
7,478
30,587
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Do you have a GoPro? If so mount it on the end of the trailer and take a test drive. Then tou can see how it does.
Reactions: joeymt33 and JTW
Jshell3
Ratchet straps are best.
Back to amazon for me...
Jshell3
Well, I was centering above the angle iron. And also thinking about loading a second ATV behind the first. So the second atv would have forward anchor points.
Ratchets off the roll bars would be pretty much straight down, opposed to the 6" offset of the receiver.
Reactions: Deltamud
swsebek
swsebek
2,854
5,835
pa
all the weight is on the tongue,Are you hauling another machine behind it?
In that case I'd run my rear d-rings for the PK5 wider and further back with a plate under the boards. Just leave the current rings for an atv.
Reactions: elkguide
