P500 Need some advice...
Ragincajun92
Ragincajun92
163
231
Kingsland, Georgia
Need some advice For my 2018 p500. I finally got all my 30-8-14 interco interforces in from FedEx. I am getting them mounted on tomorrow. I am mounting them on 14x7 msa m12 diesels with 4+3 offset. It’s my understanding and why I bought these rims to start with is the 4+3 offset is like running a 1.5 “ spacer on stock rims. Is that correct? Also since I am going higher now with the 30’s I am thinking about adding 1” spacers in the front and a 1.5” spacer in the back to help with the tippy factor. Do you guys think that will be to much and cause me problems with bearings and ball joints? Anybody running a set up like this and have pictures. Is a good idea or just leave the 4+3 rims and be done?
906UP
906UP
14,405
136,873
da Yoop
The farther out you go the more leverage(pressure) you're putting on the suspension components....it's simple physics. How much is too much?..... who knows. IMO you will likely reduce the service life of the bearings & ball joints but that is life if you want to run bigger than stock. I ran 4+3 wheels with 27" tires and really liked how much more stable it was, only got rid of them after doing my gear mod.
