Needing more an all purpose type tire for the 1000/5
boOkerT
250
1,072
Bellingham, Washington
Trying to figure out what size/brand that would be the equivalent of the tires that came with my machine but are not approved for paved. Few cops in town are beginning to write warning tickets for Off/Road only tires. I also have a clearance issue getting into my garage the tires below clear by only about and inch:
The tires that came with
Front 27x9. 00r14NHS
Rear 27x11. 00r14NHS
Not really sure what all that means....
Any suggestions on brand would also be helpful wanting still for them to work off road and on?
Thanks in Advance!
Reactions: Backwoods
Robobrainiac
Robobrainiac
2,564
9,007
You need DOT tires or you are required to have non DOT tires?
Backwoods
Backwoods
35,802
362,204
Douglasville ga
I like mine DOT approved. Absolutely NO road noise and grip really well. 10 ply also. GBC Terra Master. They ain’t cheap but they are a good tire. They come in many sizes.
1EF29CA1 D849 42C6 A5AE B2E54D6D1B56
Robobrainiac
Robobrainiac
2,564
9,007
Off the top of my head the interco sniper tire comes to mind
DOT UTV rated that can be purchased in the OE size. They're out of stock at chapmoto but Google should be able to find them elsewhere. Most DOT 14s are expensive and harder to find. Especially when you want to keep the OE tire size.
Most people on here upgrade to aftermarket 15s and add spacers to correct front to rear width. That gives you more DOT options, and gives you the ability for rotations which prolong tire life.
Highlifter still has their sale going on if you are interested in wheels.
The 4x136 vs 4x137 is a personal debate and decision. I run both sets of wheels/lug pattern on my own machine without any issue.
The Achilles Desert Hawk MT comes to mind if you want 15" wheels with LT truck tires. You can obtain them in a 27x8.50R15
The Achilles is a true DOT LT truck/highway/on road vehicle tire. @Remington enjoys the Achilles for offroad use as well.
Reactions: Scoop and Remington
Robobrainiac
Robobrainiac
2,564
9,007
I forgot to mention
NHS means Non Highway Service
Your front tire size is
27x9.00R14
Your rear tire size is
27x11.00R14
This means
Height (Tall) x Width (Wide) R Rim (Wheel Diamter)
The width of actory OE wheels are different. That is why you cannot rotate factory OE wheels.
Reactions: Remington
115,818
Tx's for the responses I need DOT tires....
To be clear with your issue and DOT’s. There are UtV tires that are DOT but what u have to watch out for is the tread pattern thats prob making too much noise on pavement that is getting the cops fired up. UTV DOT approved tires typically are off road first DOT second. DOT/LT/MT are typically DOT/road first off road second tread pattern made for road use to keep the road noise down. As @Robobrainiac stated the MT /LT’s i have work well in all typs of terrain, keep the noise down. Just your choices, you will have to upgrade to a bigger wheel and recommend same size tire and wheel all the way around.
Robobrainiac
Robobrainiac
2,564
9,007
This company has the interco.
If you read the product description I feel like it literally sums up your desires. They appear to have the factory tire size if you stick to that route.
DRZRon1
DRZRon1
1,247
3,970
PA
I forgot to mention
27x9.00R14
27x11.00R14
This means
buzz the NHS off, put a dot sticker on, see if that confuses them
Robobrainiac
Robobrainiac
2,564
9,007
906UP
906UP
14,398
136,817
da Yoop
boOkerT
250
1,072
Well after researching this and getting great advice on different tires and performance I found out that this is some sorta government/Industry conflict on what a DOT tire on a side by side standards are and hence as of now there is no DOT tire although a few claim theirs are. Hopefully in the future they will get is settled.
So its _______ still going back on forth on some of the sugestions
  • Sad
Reactions: CID and Backwoods
Robobrainiac
Robobrainiac
2,564
9,007
Most utv tires that I see "meet" DOT standards but are not "DOT Approved"
That is why most obtain 15" wheels and use true Vehicle/Truck/LT tires (those types are DOT tires.
I am very confident the interco sniper 920 is the only DOT approved UTV tire that I know of.
