P1000 New Springs on Your Fox Shocks
WagginTail
WagginTail
1,646
6,047
SC
I ordered the black viper springs from Amazon. 250lb for front and 300lb for back. Should get them Dec 6 or 7. Shocks coming between Dec 1 and 6.
WagginTail
WagginTail
1,646
6,047
SC
FYI Dave's Offroad Supply did have the black Viper springs in stock for cheaper price than Amazon but the shipping was gonna be really high. Amazon had free shipping so ended up being cheaper there. And thanks for all the info on here @P1K5Dave
Prntckt
Prntckt
1,105
7,712
Altoona, WI
  1. Talon X4
Spring compressor showed up today. Mounted the rear 300# single rate springs. Got rid of the rear squat and gained 3” clearance! Going try these out for awhile on the trail before I change out the front springs. Thanx for the recommendations. Tramguage and P1K5Dave
P1K5Dave
P1K5Dave
2,322
8,642
Petoskey, MI
3" seems a bit high... How much preload did you put on them?
Reactions: Lady01
Prntckt
Prntckt
1,105
7,712
Altoona, WI
  1. Talon X4
I have a large cargo box with tools, jack, spare parts, oil and fluids, 5 gallon fuel tank, spare tire, demountable 5000 winch in the rear. Im guessing about 250 lbs of stuff. The original spring were coil bound worse than in one of the pictures in the thread. I can dial back the preload if it turns out too stiff.
Reactions: Lady01
Scoop
Scoop
5,393
21,216
  3. Talon R LV
You've got a lot of junk in the trunk, @Prntckt ! 🤣
Soaz1000
Soaz1000
171
946
Soaz
@WagginTail Inquiring how the Vipper spring worked out? Did you use 2.5" inch in front and 3" inch in the back? You think 300lb spring in the rear are adequate with spare tire tools, ice chests, jack. Thanks
Reactions: WagginTail
WagginTail
WagginTail
1,646
6,047
SC
I'm still waiting for my front shocks to be delivered. They have been on backorder since Thanksgiving. Hopefully they will arrive before the end of the month. I haven't installed the rear shocks either. I'll definitely report back when I have everything put on.
Soaz1000
Soaz1000
171
946
Soaz
Sounds good. Thank you sir.
WagginTail
WagginTail
1,646
6,047
SC
I did go with 2.5" for the front and 3" for the rear. Here's the rear with the viper springs on
20211224 100921
Reactions: Rayger143
WagginTail
WagginTail
1,646
6,047
SC
@Prntckt how's those new springs working out for you?
Prntckt
Prntckt
1,105
7,712
Altoona, WI
  1. Talon X4
300 lb rear springs worked out great for me and I have a considerable amount of weight in my dump box. I am a very pleased with them. I havent upgraded my front springs yet but plan to do so later this year
xltman
xltman
188
369
US
I'm in the same boat. Did just the rear and what a major difference! Got rid of the bucking and was able to use the entire suspension stroke. Haven't seen a need for the front.8df9e83c10981e81d9208cceae75b26a2d0f640470a482b2530e27fc2afaaf5bE59cf07e4d83245313a7383f3d83df83
Sent from my SM-F711U using Tapatalk
