New Talon Pre-filter Snorkel
62,453
Do you think my antenna will clear the filter that high pocket will be shipping with?View attachment 314070
I'm not sure on the dimensions of the filter Brian's selling with the kit. I'll get a side shot of the clearance I've got between the window and filter though if that will help you (we've got different rear windows). You'll be really close to touching I bet.
highpocket74
highpocket74
2,162
7,147
Kinder, Louisiana
www.10-80dirtsports.com
Pretty sure the filter will not interfere with the antennae. the filter sits much further back between those 2 fender screws.
Down load this template, print it "actual size". Use it to locate the center of filter and the R2C filter is 5" diameter from that center point.
  • Talon pre-filter fender hole template_Rev-2-Model.pdf
Hometeam
Hometeam
1,040
4,392
Normal, IL
@highpocket74 I am just checking if I was on your list? Earlier on I said I would take 2 but didn't know if I was on your current list? Let me know thanks. I will be riding with @Adam490 in February and I can't have his machine be cooler than mine!! 🤓 🤣
  • Haha
Reactions: CID and Montecresto
highpocket74
highpocket74
2,162
7,147
Kinder, Louisiana
You’re on the list for 2.
definitely can’t be out cooled by Adam!
Indiana SxS
Indiana SxS
80
254
53
Madison Indiana
indianasxs.com
I’ll do it Thursday when I’m back at the house and let you know. I can always move the antenna I suppose if I have to. :)
Moab_Marty
Moab_Marty
38
40
Moab + Western CO
Re antenna move..
Just a thought...
Might be a good idea to move the antenna anyway. Having the antenna element so close and parallel to the metal window frame it
has an effect on the radiation pattern of the antenna making it directional, so more signal in some directions and less in others.
Indiana SxS
Indiana SxS
80
254
53
Madison Indiana
indianasxs.com
Re antenna move..
Just a thought...
Thanks for the suggestion. I have no issues with the aluminum frame. I trail ride so I’m normally only talking to people that are fairly close. But I hear people from far away as well. I think with it being a 25 watt radio it doesn’t matter a lot. Plus because of the riding I do I would rather it be protected then exposed to get ripped off by tree limbs etc.
thanks,
Reactions: Montecresto
highpocket74
highpocket74
2,162
7,147
Kinder, Louisiana
What’s y’all’s take on color options? I could offer these tubes in Honda, red, blue, and orange with Columbia coatings Honda colors. These colors match frame paint exactly but are slightly different than the plastic colors. There would be a $25 adder for these custom colors that the shop charges.
highpocket74
highpocket74
2,162
7,147
Kinder, Louisiana
Working out a solution with desertcraft to convert their 4” outlet filter to fit the 3” OD intake tube. I think we are close to having something economical figured out. I’d much rather use these filters. They are high quality and a great company.
Jacknmaggie
32
124
Chippewa falls wisconsin
Me personally think black. I would have to see the tube in blue and installed to go that route. I have a blue x in case u didn't figure that out🤣
Fritz-NH
Fritz-NH
12
15
NH
Look good, please put me on the list! Black works!
stellarpod
stellarpod
821
3,025
OKC, OK - USA
Late to the party, but I'm interested. Put me down for one kit, the full monte with all the trimmings. Black is perfect.
Thanks!
Steve
Will that be more likely to fit into the space restriction that I have? If this will work for me I’ll do orange….
scottkooch
scottkooch
67
241
SO MN
  1. Talon X4 LV
Have you figured out if your kit will work on a x-4 flv?
