moparornocar
RIP....Rocmar...
How thick is the sheet you're using?It's called expanded abs. Sign shops use it a lot and car companies use it for models sometimes. It's pretty hard to locate and many companies build it. Sintra is my manufacturer. Went to a local wholesale only plastics shop and they are getting me a sheet for 180 which is smoking good! Wednesday next week I'll have my grubby fingers on it. The stuff isn't designed for structural but we'll just see about that. You can screw,router,cut,drill and even finish the edges. No fiberglass or primers this time. Not 100% but I'm willing to make a mistake.
Yup. That the stuff I sawMopar here are a couple links. Keep in mind it's expensive to ship. eBay I found the best price.
Expanded PVC
Expanded PVC Foam Board Komacel - White -96"x 48" x 19 MM (3/4") Thick | eBay
I'm also thinking this will make excellent cargo boxes especially for the p500 roofs possibly many other uses. Again if you have wood working tools you can work with this.
I was thinking of something similar so I can replace that soft panel in the back with a hatchback style lift gate. How do you plan on putting a window in, route a channel and glue glass or plexiglass in?It's so damn tough. That 1/4 piece I tried breaking with a hammer in a vise. It's impressive! PVC glue amongst other things glues it. I've only read up on it but you have to leave just a little room for expansion and it'll possibly loose shape a little after 140 but not thinking that's a problem. Tuesday or Wednesday I'll be getting it so ill tell you more then I hate to suggest something I haven't used.
Sounds like you and I are thinking similar ideas. I'd also like a way to make it wrap around the cage at the end too.Router and double back the solid windows like I did on the doors. I'm working on a couple ideas on them opening glass is so much more rigid so it's easy I'll do that with front wing window in safety. Rear I'll use poly but it'll have to be reinforced with aluminum or steel because of the span and I'll be using shocks to hold it up I'm thinking
Guess i missed something.Thanks.. I've got a new build to do.. and refuse to let the socially sensitive run me off! But no jokes from me!! I will say, it's sure not as much fun as it was!!
Cumminspusher - I'd like to see you working in an aftermarket shop developing new products. Is going into business yourself a possiblilty? I mean that seriously.
I wish I could order a set of those doors.
You have my attention my friend.
Preliminary rear windows underway. Kinda tricky getting form and function combined on this on. It's got to seal and look factory. Lots of angles! Need more beer!
Coors Light needs to sponsor your build! Materials and 1 case a day- Is that good terms?
