P1000 Oil dip stick
drfubar
drfubar
TheDonFather
5,889
19,233
Mary's Ridge (Dayton Mtn), TN
Is it my old eyes or is the dip stick "good oil" range about a quarter of an inch? What a pain that is. Also do you have to screw the dip stick all the way in and pull it back out to get an accurate reading? I'm guessing yes.
Dasmoeturhead
Yes, and no you do not screw the oil dip stick in.
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
Did.. still not registering on stick
make sure the dip stick is correct you should be able to screw in but don't then check it if it's at the wrong angle it will not reach the oil.
267,628
You have to follow the multi step process in your owners manual exactly or you will not get a proper oil level reading. I'm not going to bother to retype the process when it is in the manual included with the machine, a bit of a PITA but that is what has to be done.
Upstatefreedom
Upstatefreedom
224
410
Colton,New york
No? Well then my oil does not even register on the dip stick!
If that's the case and you did check it properly, I would call the dealer and inform them. Even though it's prob. Only 1/2 qrt low in a roughly 6.5 qrt system. At least it will be on record if you ever have a problem. (Not that you will from a Honda). I'd be surprised if the dealer didn't perform a pre delivery inspection.
hondabob
1,167
4,556
Prescott Valley, AZ
Yes follow the owners manual and still no oil screw it in and check it. That will let it go another 1/2 inch. If there is oil just add a few ounces. It holds a bit over 6 quarts.
Reactions: Haldog77 and sharp
L
LBZ_Duramax
26
14
Mine was almost 2 quarts low from the dealer when I checked it the next morning before riding. We had a "chat" about that....
drfubar
drfubar
TheDonFather
5,889
19,233
Thanks for the great responses. My first Pioneer but not my first ATV/UTV. I did the the oil check, "by the book" yesterday, I had the dip stick in straight because I had it screwed in thinking that's the way it's supposed to be checked, (it should have read high). My Polaris was checked in that manner so figured the Honda was the same. I'm going to the dealer today and let them know about the oil level right after I check it again this morning. I'll post up here on my results.. Thanks again boys.
N
Nightcrawler
103
229
Portland, OR
Oil? Who needs it? Don't you know that sh** will just make your clutches slip?;)
Reactions: drfubar
drfubar
drfubar
TheDonFather
5,889
19,233
I feel stupid! This morning I checked the oil, but this time I wore my glasses. Oil was fine, I just couldn't see the fresh oil on the dipstick well enough without my glasses. Don't get old boys cause it's hell... LOL! I actually feel a lot better now. DJR
sharp
sharp
3,757
14,955
Tennessee
It's usually the simplest things!
Reactions: drfubar
TractorMan
TractorMan
98
159
I hear that. My Ma'ma always told us kids that getting old wasn't for sissies. I now know what she meant. :)
Reactions: drfubar
drfubar
drfubar
TheDonFather
5,889
19,233
And I want everyone to know that my Honda Oil was delivered today and my filters are at the post office... Thanks for all the good information.
Reactions: sharp
ghost
ghost
993
1,873
BC
The dickstip is hard to read (you heard me) and the procedure for measuring the oil level is assanine.
