P1000 Oil Viscosity
russknight
russknight
1,910
7,511
Perry Florida
I live in the south where the temperature is usually warm, even through most of the winter. I was thinking about using 20W-50 full synthetic motorcycle oil designed for wet clutches in an attempt to quiet the transmission down.
Thoughts?
JimmyA
JimmyA
1,644
5,504
Northeast texas
In your climate zone, I would use 10W40 syn or dyno! I am using Honda HP4 synthetic cuz that's what I have and use in Goldwing.
Reactions: russknight
ehart814
ehart814
1,655
3,645
NWPA
In the owners manual, it shows temperature ranges and the acceptable oil viscosity. I can't remember if 20w-50 is listed there for high temps... but I know 10w-40 is and that is what I use.
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
Personally, I would do the OEM recommendation and if you are concerned, then I would make the intervals between change half the time period recommended.
russknight
russknight
1,910
7,511
Perry Florida
My chief concern is using the right type of oil. I'm willing to experiment with the viscosity, I just don't want to screw the clutch discs up. Is a full synthetic motorcycle oil that is specifically designed for use with wet clutches acceptable?
JimmyA
JimmyA
1,644
5,504
Northeast texas
Mobile 1 makes a motorcycle oil and I have used it in my Goldwing also.
Todd627
Todd627
56,736
619,452
MI
Mobil 1 racing 4t oil
russknight
russknight
1,910
7,511
Perry Florida
Update: Changed engine and transmission oil to Valvoline 20w-50 full syn JASO MA motorcycle oil. Engine blew up. Just kidding..... Can't tell any significant difference other than shifting may be a bit smoother. No noticeable noise reduction.
Similar threads
