needs pics of you machine, as well as radiator
year and mileage?
any other engine or machine modifications?
obvious questions below
-fan runs
-fan turning correct direction
-is radiator really really clean
-if you remove tune, does it still overheat
did it overheat before the FCP tune?
Florida cracker performance tune and yes it did it did when I was still mostly stock I think I rode with just a snorkel for long time after the tune it got better but I don’t ride roads often I normally in the mud and water not going very fast is there a way to clean the radiator better without having to remove bumper and front plastics
2021 pioneer 1000-5 limited about 900 miles I think
Set up:
Duel battery
Tune
Satv aarms although ttc are on the way
6klbs winch
All rhino 2.0 axles
6 in portals
33x9.5x20 acp tires
All new axle seals
Depth finder snorkel that was my first upgrade could this be the issue?
fan dose run vehicle must be running for fan to run which I find odd
Have not checked fan direction I just assumed it was good
radiator is such a pain in the ass to clean threw those little grill holes I think it’s clean
No I have not removed tune only because it got better after the tune
