P1000 P1000 Storage Fume Question
Plumber101010
Plumber101010
597
584
Western NC (Hayesville)
Going on a road trip for a few months and putting the 1000 in a storage unit. I’ve always kept it under a carport. Does anyone keep theirs in an enclosed space, like a garage?
Just wondering if fumes are an issue and if anyone smells ANY gas smell at ALL when they do or whether I’m safe and good to go?
Suggestions for storage? Assuming I should either run some Sta-Bil through it OR run it till empty and runs out of gas? Guessing again running out of gas could reduce chances of fumes if leave cap off and let air out.
Thanks
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
Use stabilizer with a full tank of gas. I always keep mine in the garage.
Reactions: TheHoover
ToddACimer
ToddACimer
Pioneer 1005-2
3,564
14,633
Oshkosh, Wi
Mine smelled like fuel when the tank was full before I extended my vent lines. No more smell with longer lines
DDDonkey
I just got back from a month long trip and Han no issues. I put fuel stabilizer in the tank and put it on a trickle charger.
Reactions: Redmoon
dilligaff82
157
315
New Hampshire
Mine stays in my garage full time. No issues with fumes of any kind. As for a stabilizer I use startron. I run it in everything and never have any fuel issues, even after leaving stuff like the lawnmower parked for 7 months out of the year. One ounce per 5 gallon gas can is all it takes. Only other thing I’d do if I was you is leave it hooked up to a battery tender JR.
It will be fine as is.. the fumes won’t be bad if the tank isn’t completely full or their aren’t big temp swings and blazing hot.
TheHoover
TheHoover
221
694
PNW
hondasxs.com
I store mine in the garage. No fumes. I try to keep my tank full or close to it. Ready to go! I also seen on here somewhere that something rusts if left empty? Not sure what part it was now.
dilligaff82
157
315
New Hampshire
If we’re remembering the same thing, I’m pretty sure the whole sending unit in the tank rusted all to hell. Chunks of rust flaked off and googled the pump and/or injectors too IIRC
Edit: found it P1000 - Important Photo of Fuel System
