P500 P500 Snorkel - 2" Dual - specs and detailed photos
  • Thread starter Deleted member 3748
  • Start date
Redrocket
Redrocket
56
58
Lake City FL
Just down choke it down at all. Maintain at least 2" of air flow and it'll be good to go.
Yeah trigger I'm hoping oem tube is 2 " I'll cut it off at the fender and )0 up from there. Hopefully it will work long as I'm staying with same as original size.
11,322
84,140
Excellent details! Would make a great You Tube video. Need you to take a job writing instructions/consulting for some of the aftermarket stuff. (EZ steer...are you listening?). LOL
Deleted member 3748
Thanks! Haha. I used to write 100+ page documents for HP so the field technicians could build server farms for customers.
Reactions: trigger and Mudder
11,322
84,140
@PistonHonda , Check out the rodent guard or insect screens for 2 inch to keep leaves or stuff out for a finished look.
https://www.amazon.com/PVC-Vent-Screen-Insects-PVS-IS2/dp/B00O3A7ARY?tag=sxsweb24-20
https://www.amazon.com/PVC-Vent-Screen-Rodents-PVS-RS2/dp/B00O3A7FI8?tag=sxsweb24-20
https://www.amazon.com/Camco-42141-Flying-Insect-Screen/dp/B00192JFBI?tag=sxsweb24-20
D4DEA055 B6D4 4A07 9291 291669BD6D23 6288C9B1 3CD8 4B92 9F06 8B4291C9E15E 39041ED9 8FC1 4C3D 91C0 4469DBF3BE37
Deleted member 3748
Those look pretty sweet! I need the extra filtering of the prechargers because my airbox is a dirty mess
G
Gassygordo
302
1,025
Fillmore, NY
OK, did your fine snorkel job cut down on the intake noise?? I just installed Triggers noise/heat insulator which really cut the engine noise, but wow, now I can really hear the little P5 suckin air. Sure would be nice if I could cut back on the intake noise!
Deleted member 3748
The snorkels were very loud when I put the rear panel on so I cut holes in the rear panel shop the ends would be outside. If I still had the 500 I was considering adding a larger chamber in the snorkel to capture the noise. A bigger piece of PVC pipe in line that would look and act like a muffler.
G
Gassygordo
302
1,025
Fillmore, NY
Thank you! Been looking to try that. If I do, I will post pics. Thanks again!
156,910
That's the best review I could ask for as far as noise reduction, thanks Gordo! ;)
