P1000 Pioneer 1000 regret
jwfirebird
jwfirebird
927
1,446
western ny
My suggestions: Non ethanol 87 gas, I would drain the tank and put fresh in. Relocate the gas tank vent, it is known to cause water in the tank. Replace the spark plugs, mostly insurance but if you foul one good they tend to not run 100% no matter what you do to clean them. You do not have to remove the air box to change plugs (not hard to) but do need a couple 3" extensions and a magnet to get them out, pretty sure the plug is a 14mm. 0W-30 oil. You have to have a pretty hot battery for these things to crank. I would leave it on a battery tender or even better get a battery heater or tender and block heater for those - temps.
ethonal free gas does not have the winter additives the gas pump stuff does, maybe good for warm area for its storage benefits but is need to make a vehicle run properly in the north. the cars and trucks run fine forever in neg temps. the only disadvantage is you have to use stabil if you dont plan on using the gas in less than a couple weeks because of the ethonal. honda must push the 100 because the lady said it had it in the tank from the factory and that was what they recommend you keep in it, but you will have problems if you do in the cold
Reactions: Plumber32
66,387
A lot of guys posting on Facebook about this issue. Gel battery and heet in the tank has been the fix for the no start in the cold issue.
Reactions: JTW
Vikes79
Vikes79
SKOL!
10,884
105,611
South Dakota
  2. Talon X4 LV
Don’t forget that as temps lower the availability of effective cranking power also diminishes. The inverse is true for recharging the spent energy as well.
Lots of stops and starts in cold weather is hard on these small batts.
Chris-Rog
47
96
Well to my surprise it started today, fairly easy actually. But.......it warmed up today to 13 degrees Fahrenheit. Thank god I was able to plow in this blizzard. Weather is supposed to drop off again to minus 15 I think tomorrow. Really appreciate everyone’s input.
sharp
sharp
3,757
14,955
Tennessee
Glad to hear you got it going! I read your first post and was thinking, if you bought it brand new and only put 8 miles on it, the dealer must have put bad gas in it to begin with. I dont see how yall deal with that cold weather. Lol. It was 57 degrees here today and they have already cancelled 60+ schools and counties for tomorrow because we are expecting a dusting to 1 inch.
Vikes79
Vikes79
SKOL!
10,884
105,611
South Dakota
  2. Talon X4 LV
Tomorrow in mid eastern SD.
E18A1BA0 88A3 4CD8 B5FC 710AFB306A03
Wednesday looks similar....yay!
Choogsbro
Choogsbro
CEO of Monkey Business
8,144
52,659
Monticello, Ky
-35, wow that’s brutal. Sharp, my daughter went to college in tn and she would send us pictures of totally empty milk and bread shelves if they were forecast to get an inch of snow.
Yes they are the same way here in Ky. I'm from NE Ohio snow belt area. I laugh at these crazies down here. Good people but clueless about real snow.
Reactions: Plumber32 and sharp
JsheII3
JsheII3
Long time listener.
339
1,534
Mississippi
These are my favorite threads. @Chris-Rog has a legit issue and multiple members give sound advice. *(note to Chris-Rog... I know you don't have much post history w/ Hondasxs Forum, but these guys answering you, hold in the HIGHEST regard & Consider them Top Experts!)
Keep us POSTED! Don't disappear.
Choogsbro
Choogsbro
8,144
52,659
Monticello, Ky
These are my favorite threads. @Chris-Rog has a legit issue and multiple members give sound advice. *(note to Chris-Rog... I know you don't have much post history w/ Hondasxs Forum, but these guys answering you, I hold in the HIGHEST regard... You should consider them Top Experts!)
Absolutely true. I own a Yamaha but this a great forum all the way around.
66,387
This cold sure puts a hurting on the old liver! Really why not get drunk and be hung over. Ain't nothing else to do!
Reactions: Mudwing and sharp
