iowaguy
Thanks, now I have to decide how I want to fasten it to the main cage with out spending money on expensive connectersLooks really good!
In all honesty since you have the fabrication skills...Thanks, now I have to decide how I want to fasten it to the main cage with out spending money on expensive connecters
Found some clamps that will work for me, don't have to do any welding on the sxs roll cage, chain link fence T Brackets,$8.00 a piece.I can put a bolt thru the bracket and pipe if I think l need more strength, but I don't think it will be needed, this one is on the cross bar in the back, the idea of this is to be able to completely disassemble and store it when not in use.In all honesty since you have the fabrication skills...
the way it is on the factory p1000-5 would serve you very well and have the bonus of being removable!
Found some clamps that will work for me, don't have to do any welding on the sxs roll cage, chain link fence T Brackets,$8.00 a piece.I can put a bolt thru the bracket and pipe if I think l need more strength, but I don't think it will be needed, this one is on the cross bar in the back, the idea of this is to be able to completely disassemble and store it when not in use.View attachment 8179
Took the words right out of my mouthI tend to over build things for worst case use.
For not much more money about $20 each.
STV MotorsportsSteel Clamp 1.75" (1 3/4") Universal Roll Cage Tube Mount Weldable (4) https://www.amazon.com/dp/B0108ZVM8K/?tag=sxsweb24-20
i.e. A monkey that tears up an anvil with a rubber hammer.
That fence clamp would scare me if I rolled it for some freak reason, I feel like it would bend and turn the end of that tube into a mace or spear.
I guess I would also ask have you force tested those brackets? Are they cast? The structural strength of some cast products scare me since they are mostly sourced from China. I have seen how just a tiny bit of air or contamination in a cast metal product can limit strength. Ultimately, it's your project and whatever you are happy with. As a "stop gap" measure, I think it looks good!Found some clamps that will work for me, don't have to do any welding on the sxs roll cage, chain link fence T Brackets,$8.00 a piece.I can put a bolt thru the bracket and pipe if I think l need more strength, but I don't think it will be needed, this one is on the cross bar in the back, the idea of this is to be able to completely disassemble and store it when not in use.View attachment 8179
I don't think that will be an issue for meTo much weight in the rear
Front tires will float at
Higher speeds
Please note in post #3 that it is solely for kids to sit in. I think he has considered the weight aspect and doesn't plan on toting around anyone my size...lol. Then, he would have all kinds of problems like you stated...Buy a four seater...if it was suppose to have back seats...it would.
You do wat ya want... your gonna be top heavy. ..weight past your back wheels...front end will float...ive done all this
No I'm not a mechanical engineer, my son in law is and it has to meet his approval for the kids to ride back there,I have been a CNC machinist programmer for the past 29 years ,and I stayed at a holiday inn express once.Front tires wont float do to mid engine but that said you do realize its illegal most states to ride passengers on atv that arnt designed to and ALSO i doubt that you are a mechanical engineer to design the p5s rear to protect kids in a roll over weve all done stupid s*** like crazy s*** but do that to yourself and not kids or anyone else buy a 700/1000-4 play it safe and keep everyone safe dont risk safety for any reason
with the fence post Ts he said it was safe for kids I don't think so those things have a hard enough time handling kids when they jump fences let alone a 1000lb machine plus ppl and I prefer bates motel over holiday innI'm not a mechanical engineer, my son in law is and it has to meet his approval for the kids to ride back there
The only place the T's are used is across the back for headrest to be mounted on.These are the brackets I am planning on using to connect to the cage, two pcs.with four 5/16 hardened cap screwswith the fence post Ts he said it was safe for kids I don't think so those things have a hard enough time handling kids when they jump fences let alone a 1000lb machine plus ppl and I prefer bates motel over holiday inn![]()
