P500 Pioneer 500 glove box interest
scottp500
scottp500
46
65
Installed mine today, only took a couple of brewski's. Good fit, just take your time cutting the hole and you should have no problems. I did have to move my winch solenoid but that wasn't much of
DSCF0201
an issue. Thanks again for making these.
Chooglin
Installed mine today, only took a couple of brewski's. Good fit, just take your time cutting the hole and you should have no problems. I did have to move my winch solenoid but that wasn't much of View attachment 16566 an issue. Thanks again for making these.
Looks great...........I'm glad you like it !
194,106
That was a breeze to install. Well thought out and designed.
Put some black two sided tape on back of flange, probably didn't need it but...
1 coat of prime, 2 coats of finish inside and out...looks like it grew there.
Nice job Joe...Thanks!Glove Box
markie
466
602
milton kentucky
Nice job Joe...Thanks!View attachment 16660
I thought about doing the same with mine when I get it
Chooglin
Thanks @trigger looks real good !
Did the bolt on the bottom of the box, line up pretty good with the tab on the frame ? I was a little concerned about that , thought maybe the tab would be a little different on each machine !
194,106
Lined up perfect. It sits pretty solid with that bolt holding it in.
It's actually bigger inside than I thought it would be. Sweet!!
Reactions: Chooglin and markie
