P1000 PIONEER DYING WHEN PUT IN GEAR
CASTRATE
CASTRATE
77
350
53
NE OKLAHOMA
My tractor was having all sorts of issues. Most of which ended up being a result of a screwed up alternator. After a while, it would stop charging. Power shift, reverse, 3 point & a few other things would quit working
Reactions: Lady01
WhiteLightning
WhiteLightning
1,640
5,909
Magnolia Arkansas
I have a 2016 pioneer 1000 that starts great idles great even revs up fine in park but once in gear and riding it starts cutting out at half throttle any ideas
My 16 was doing exactly the same thing. Loose ground cable to battery was all it turned out to be
Sent from my SM-G965U using Tapatalk
JDPioneer
JDPioneer
Iowa
Mine did this the other day,(2017 2200 miles) about an hour after pressure washing it. I drove it around the yard and shifted into park and it died and would not start. Turned out it was flashing code 64 (six long 4 short). I did some investigating and the IGN fuse was blown. I replaced the fuse and it would start but It would keep popping the IGN Fuse after I tried shifting to a gear. After searching for a related issue I read someone had replaced a relay and it had fixed the problem. So I was looking at my relays and pulled the main relay next to the fuse box and remembered there was a spare in my operators manual zip lock bag from the factory. I then put the new one in and it has been fine sever since. Although it did randomly overheat the next day going steadily 15 mph. Im not sure if this was related to the issue the night before or not. Possibly my battery is getting weak, it is 2 years old now. Any Ideas?
Reactions: Lady01
A
Akhazmatt
Palmer, AK
Mine did this. I was using the winch to get out of a hole. The winch pulls the battery voltage down too low on a long hard pull. Engine died. Putting it in park or neutral I can restart then when putting it back in gear it dies. Being an old mechanic I cycled the key three times to clear any faults. It worked. This has happened several times when using the winch hard so the problem must be a low voltage issue. The dealer said I have no stored fault codes and can’t say why cycling the key fixes it. I plan to add a second battery. Hope this helps.
Black19
Black19
Mississippi
Did anyone ever get a fix for this? Mine started doing this last night (2019 100-5 deluxe). I was in a hole, put it in reverse to get another angle and she died immediately. Will crank fine and I even managed to get it in neutral and winch myself out but as soon as I put it in gear it dies. No code showing and it displays all gears when shifting with key on.
Reactions: Lady01
Black19
Black19
Mississippi
Well I tried all advice here on the forum and anywhere else google would take me. Tried all the little things everyone suggested with no luck so after three weeks at the dealership I’ve got a new clutch and going to pick it up in the AM.
P
Paulwaul11
Maurice LA
Mine started doing the same thing this morning. Everything ran fine yesterday. Couldn’t take it off the trailer this morning. Crank and runs in Park and Neutral but dies immediately when put in gear. Rolls fine in neutral. There is a “—“ blinking in place of the gears. It does not read P,R,N,H,L. Any tips on what to look into? Doesn’t make since everything was fine when I loaded it on the trailer.
Reactions: Lady01
Manis
Pioneer Tn
Did you get it fixed
Reactions: Lady01
Slackjaw
Slackjaw
294
462
Durham NC
Have u modded any electrical? Reverse buzzer and neutral switch will kill it like that.
@snuffnwhisky
I attached a backup light to the reverse buzzer (used the plug from the club store) and my 2019 p700 started stalling out. I disconnected the light and it still happens.
Could just be coincidence but can you tell us more about this? The connection is keyed so it can't go in backwards. Red/black to the light. I even put the little connector blank plug back in case it had a resistor in it or something.
What about the reverse buzzer can cause this?
Thanks!
Reactions: Lady01
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
@snuffnwhisky
Thanks!
I do not know about the 700. My 1000 reverse light I used had a ground wire but was also grounded through the body of the light so it backfead a ground signal continuously and killed the motor going to a different gear.
Reactions: TripleB and Lady01
Slackjaw
Slackjaw
294
462
Durham NC
That sounds odd. Ground is common, so it shouldn't make any difference. So did you use a different light or took another approach?
Reactions: Lady01
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
I added a relay so it wouldn't backfeed. The light housing and ground wire had continuity so when I bolted the light to the frame, it grounded the ground wire and fed that back to the buzzer. ECU is wired through it so Gear position switch and reverse switch doesn't match and shuts it down. A bad neutral safety switch will do it also.
hubbard1986
michigan
Key on. But NOT running.
Put it in D, R and L. Does the display show correctly in each spot?
Or is it a -- .
Thanks.
Was this problem ever figured out? Mine did it yesterday when started it wouldn't show any gear position. Let if run for awhile then cycled key a few times finally showed park.
Reactions: Lady01
rickoshea
mine's in the shop right now for this issue.flashing code 24,12 and 40 something.
Reactions: Lady01
V
Vtt1000du
Canada
Mind running good at the biginning but after awhile it's start dying. Some say it the fuel injector plug kit and others say sparkplug. What do you tink?
V
Vtt1000du
Canada
Is it throwing any codes on the dash?
If it is, video it with your phone, upload to youtube and link the video for us to help out.
Did you find your problem, I have the same I think!
