P1000 Please Help, 1000 Dies and won't go into Gear
Jason-2119
19
45
Central MN
I haven’t had any problems with my P3 yet but it’s nice to see there are smart guys out there willing to help.
Reactions: TripleB
Hondaking2016
Hondaking2016
missouri
Well installed new shift motor did not solve my problem. Gonna look at all grounds.
Reactions: Lady01
Hondaking2016
Hondaking2016
missouri
Changed Shift motor that did not help. Checked grounds today and readjusted the rear differential.
None of this helped.
Reactions: Lady01
slowdryrider
slowdryrider
574
784
Canada
Been away for a ride yesterday. Your mentioning about turning the key on and hearing clicking and and the it shifting down made me assume shift motor problem as this was what mine did. Another guy mentioned mentioned about changing the shift motor and his machine still didn't work properly. His find was that the wires going into the plug on the shift motor were pulled apart or slid out of place inside the plug. I'am not sure if it was due to unplugging the connection at the shift motor and then plugging it back in realeasing one of the pins inside the plug. Also any rubbing through of the wires anywhere or breaks in the wires will cause inssues. Nothing fun about trying to figure out electrical issues.
Reactions: Lady01
W
wstsidesrf
9
torrance
ok guys, I replace the control motor, Honda ran good for 8 miles, then got stock in 1st gear. after I let it sit and cool off, it runs perfect for about 8 miles then first gear again, any help?
Reactions: Lady01
slowdryrider
slowdryrider
574
784
Canada
Not sure what to say. Just throwing this out but when you turn the key on do you hear it shift into N after it cools down. I've read that sometimes the new ( if cheaper quality shift motor ) can be at fault Why don't you try taking and cleaning up the oem one and after you have it cleaned up put it back in and see if it makes any difference. ?? It's worth a try ??
Reactions: Lady01
W
wstsidesrf
9
torrance
I put a OEM from Honda. It runs like normal after cool down
Reactions: Lady01
slowdryrider
slowdryrider
574
784
Canada
when you get if figured out post what the problem was ,this way it will help others sort out there's.
Reactions: Lady01
W
wstsidesrf
9
torrance
anyone have a Idea why after 20-30 min, tranny will down shift then stay in 1 gear? no engine code
Reactions: Lady01
HondaTech
When you check grounds, don't just hand check them.
The one next to the starter motor has known to feel tight with a tug on the wire. But the bolt will be stripped and wont tighten.
Reactions: Lady01
bumperm
bumperm
1,918
6,806
Gardnerville, NV
In aviation, as well as other industries too, a dielectric grease (Dow DC-4*, silicone grease, or other specialty brands) are used to both waterproof connections and prevent corrosion. Though dielectric grease is an insulator, it doesn't prevent metal to metal contact while it provides a gas tight connection to prevent corrosion and resistance build up.
Anyone using dielectric grease on ground connections etc.?
* Now known as DuPont Molykote 4
MolyKote 4
Or Permatex version for less:
Dielectric grease
Reactions: Jerryg and Lady01
L
LarryAmboy
906
2,018
Castalian Springs, Tennessee
MolyKote 4
Dielectric grease
Yep, on all open to air connections
Hondaking2016
Hondaking2016
missouri
New shift motor, battery, plugs, angle sensor at gas pedal.
Still having issues with it not wanting to shift from 2 nd to 3rd properly
Reactions: Lady01
slowdryrider
slowdryrider
574
784
Canada
Are you saying that your problem is that it's not shifting from 2 nd to 3 rd. So if I'am reading this properly your problem is different than what others are having when there [my] machine actually shut down because it wouldn't down shift. Once cooled off it would work for awhile then shut down because it wouldn't shift down when it warmed up. So really your problem isn't the same ???
Reactions: Lady01
Hondaking2016
Hondaking2016
missouri
Got my service manual today its saying code 57 could be the TR sensor. Now what the hell is the TR sensor because i don't see that name listed on the sub transmission parts list
Reactions: Lady01
bumperm
bumperm
1,918
6,806
Gardnerville, NV
Not often, or even really, but sometimes Google seems like a friend:
"What happens when a transmission range sensor goes bad?
The Transmission Range Sensor tells the PCM the position of the transmission shifter. The PCM uses this information to control which gears of the transmission to enable or disable. When the TR sensor fails it can cause wrong gear starts, no upshifts, or what feels like a falling-out-of-gear condition."
P1K5Dave
P1K5Dave
2,284
8,536
Petoskey, MI
I think I remember that in my sub-transmission service breakdown, when I pulled it to replace reverse and low range.
I believe it was one of the electrical plugs I had to pull on the outside of the sub. I'll dig a bit and see if I can help...
Reactions: Lady01
Hondaking2016
Hondaking2016
missouri
Exactly but I cant find the TR sensor anywhere. It's in my service manual which doesn't give part numbers. Dealer couldn't even help me, nothing listed
  • Wow
Reactions: Lady01 and Jerryg
