906UP
I'd really like to gear my little donkey up, not a lot but hear me out.....
I've been doing a little research, pouring over Honda parts lists. The transmission counter shaft and final shaft are the same in the Rancher 420 & Foreman 500.... OK, no suprise....everybody knows that...
Ah ha.....there is a difference, the drive(gears) between the counter shaft & final shaft are the same for the Foreman 5 & P5 at 16/30 for a ratio of 1.875, on the Rancher 420 the drive between the 2 shafts are 25/37 for a ratio of 1.48.
I'm thinking it'd be possible to swap these gears out, it would give an approx 25% overdrive. I think it might be doable with the low gearing we already have. Even with 27" tires I find myself in 4th & 5th most of the time.
2016 Honda Pioneer 500 (SXS500M 2AC) FINAL SHAFT | Babbitts Honda Partshouse
Parts #2 & #3
2016 Honda TRX420FA2 AC FINAL SHAFT | Babbitts Honda Partshouse
Parts #3 & #4.....and maybe #5
Pic below is from a 01 Rancher but it's still the same design.
Parts #2 & #3
