P500 Post your rear rack or box. Pics.
BURNDOG
BURNDOG
84
229
Oregon
Here’s the finished product!
View attachment 72484View attachment 72485
I’m curious about the bed liner. Did you use roll on or spray on?
How long have you had it on there and how is it holding up?
Did you prime it first or lay it on bare wood?
I would imagine there would be no need for primer, adhesive qualities would seem to be great on a surface like wood.
And finally.....
Damm fine piece of work there dude👍
Wonder how the coating would work on plywood?🤷‍♂️
Hoop
I made plywood box with a removable storage box
WIN 20201009 172447 WIN 20201009 172456
nctrailboss
nctrailboss
440
1,454
north carolina
How did you mount the box to the rack? I’ve come up with several ideas, not sure which is best.
I have a box from northern tool and the Strongmade rack.
The box came with 4 "J" hooks,they hook around the round bar of the oem rack.I also bolted it to the square rack that I built.It is very secure,as my homemade rack is bolted through the flat center section of the oem rack.
Behindbars
14
Orange,TX
Looks great. How did you mount your box? Just looked and j hooks didn’t come with my northern box.
I purchased some ubolts for 1”pipe. Used two on each outside pipe.
Reactions: J80
NTC/TAP Transition Member
11,795
89,701
Conduit clamps also work to hook the rack.
Reactions: J80
Raghorn
Raghorn
142
627
PXL 20201023 161905103
Metal basket with rubber mat bottom. Spots where you can slide in 1" square tubing to extend upwards in case you need extra height/walls. Thinking of mounting the gun boot on the inside wall (kind of where you see the spare). Then, mount the spare on the back.
Here it is loaded with a small buck my buddy's son got yesterday. It's his first deer.
SC_Dale
SC_Dale
5
Iowa
Just got the one I built, mounted today. Started (like many) with a Delta pickup side box and went from there. I used 1x2 aluminum channel scrap I had and 10ga aluminum sheet to complete the box. 1/4 and 3/16" pop riveted together. Ubolted it onto the rack. I plan on truck bed liner on the inside at a later date.
IMG 5955
IMG 5954
MtClimber500
MtClimber500
62
170
Butte, Mt
Homade box setup. Room for gun scabbard in front and in back of box. Box keeps things dry. Put little rack on top of box. Also have added large mudflaps to hang from rear bumper. Mud flaps keep down most of tire mud splatter.
Pioneer 500 3 2020 Honda Hunt2
MtClimber500
MtClimber500
62
170
Butte, Mt
Reactions: J80
