P1000 Power commander V
RZRBound
RZRBound
12
Southern IL
We should start a bin library on here. Dyno Jet's site only has one map, and that was peaky as crap...
Poorboy1957
Poorboy1957
65
86
tennessee
Here pic of last tune. you can see auto tune removed lot fuel in lower rpms
356E7EE9 910F 416E B014 B88BD1707F11
RZRBound
RZRBound
12
Southern IL
Interesting... So the stock tune is actually rich in the higher revs? What was your target? 13-13.2? Stock intake and exhaust? How long was this table auto-tuned?
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Make sure to calibrate the TPS in the software. If you see your TPS going from 0-1% at idle, It will start making making changes to idle at your 2% settings. I adjusted my 0% and 2% @ 1000 - 1500 rpm the same. Smoothed out the idle a lot.
RZRBound
RZRBound
12
Southern IL
I noticed and did the exact same snuff... At idle it even occasionally see's 3% so I made sure even 5 tps isnt a huge difference... Do you have an auto-tuned map completed yet? Like to compare mine
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
I've got a different cam so my map is a lot different.
RZRBound
RZRBound
12
Southern IL
Did the cam make a big difference? Was just looking to compare the curve actually... not specific numbers
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
It lost bottom end but picked up mid-upper range. Supposed to get my IGR back this week so the bottom end should be taken care of. Idle is at -22%, 8k i'm +30 at 13.2. 0-55mph I'm 2-3 bike lengths behind at the start and 2-3 ahead at the finish.
RZRBound
RZRBound
12
Southern IL
Wow! So she is opened up now! 30 plus percent more fuel than stock up top.. The -22% at idle is shocking
Scubacat
New guy here. Don't own a Pioneer yet but researching for a possible purchase.
I do have the PC5 on my Aprilia sportbike with the AT. It is important to remember that it's not always about tons of extra power. It's as much about RESPONSIVENESS and SMOOTHNESS of the power you HAVE or WILL GET. In my bike I run ONLY ethanol free 90 Oct. Ethanol gives you LESS power (it has less potential BTUs of energy for a given volume than straight gas BUT is more resistant to detonation). 90 Oct is PLENTY for the Pioneer that has a 10:1 compression ratio and the lack of ethanol makes the gas it has more "power" packed ( as well as less likely to attack various fuel system components that are ethanol sensitive).
The PC5 with AT will be a pleasant addition just for the "fringe" benefits one gets and at least on my bike, makes it nicer to ride as it's smoother power delivery inspires confidence and safety. I would buy again.
Remember, an engine is just an air pump, to see benefits, you have to lessen the restriction points. A free flowing exhaust is worthless if the intake side is the restriction and having a K+N on a wide open intake pipe is worthless if the throttle body and head can't flow what the engine needs. On a non-racing machine, I personally wouldn't bother with anything beyond bolt-ons, your ROI will be so dismal.
dale5740
dale5740
886
417
mt airy md
Nope no silver. I dragraced for around 17yrs with most of that using nitrous. Proud to say I never roasted one. Went through a few rod bearings but that was a manufacturing problem.
must have been running a busa lol
Leukic
Leukic
314
995
Leesville, South Carolina
I have a 2018 1000-5 Deluxe STOCK and keeping it that way exhaust wise. I am looking at the PC-V and ATune. Is it worth $1k for what small upgrade it makes. I am not going to tune this thing like I dyno my Corvette.
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Think its about $550 for both. With stock tires you might not notice it as much. With big tires it does help. The main thing we noticed was the off idle and initial pull from a stop was better. 30" tire in 4lock in a bind and it might not even pull the tires. Just bog and sit with out the PCV.
Reactions: JTW and Ragnar406
Leukic
Leukic
314
995
So bone stock it is not worth it?
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
My friend would jump me a little over a bike length with both on stock tires in the first 30' and would be 1.5 ahead at 50 mph. Pretty noticeable off idle. Really just depends on how you drive it, weight and the terrain.
Reactions: JTW
Leukic
Leukic
314
995
On trail terrain does it provide the low in torque that I am missing... or I think I am missing I use sport mode and use low gear and it just feels like I need to give it more throttle than I should have to, to go up certain terrain rocks( not wet or slippage issue) just up hill. Maybe I should use manual shift and low gear with 4wd and it would have more Torque?
Yes... then just drink and Red Bull and you can fly over s***! Pretty sure that’s what @Cuoutdoors did.
Reactions: Ragnar406
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
4 Lock will use up more power than 4wd. I generally only use manual mode on the trail. It is 2,000#+ loaded. The PCV will give you more response if it bogs and pull better in the lower rpm ranges.
